So I started hearing my fan getting locked in when driving around town in pretty mild weather and raining sometime, but I couldn’t figure out why it was doing that given that my ECT was between 188 and 195 and my EOT was between 193 and 198 the whole time.. I pulled up the AIT on my X4 and that’s when I saw it was up over 112 which would cause the fan to engage.. this just started happening at the end of a roadtrip the other day, so I’m a little confused as to what could have gone wrong with the AC? When I don’t have the AC on, it never locks in and runs fine, which is what I am looking to get as the end result. When I start the truck with the AC on, it will blow warm air to start, but then cool off eventually.. pretty normal in my opinion, but I figured I would offer as many details as possible. The temps that I am running the truck in vary from 70 in the morning to mid to upper 80s in the afternoon in Illinois.
Sounds like the sensor is bad if the outside temps are only 80 degrees max. If I understand you correctly, you're saying that you think the AC compressor is generating the heat that the sensor is reading and causing the fan to stay on?
