In my 2004 6.0, the air dial includes (among others) choices for AC max, AC, upper vents, and upper+lower vents. Cold air comes out nicely when I select AC max, or AC -- that's working just fine. And When I select upper vents, the air is not chilled -- which is also fine. But when I select upper+lower vents, the air is chilled: the AC compressor must be running to do this, even though I didn't select one of the two AC positions.
Could someone with a similar rig test this, and let me know if it's an intentional design feature? I can't think of a reason for it -- it's not a setting you'd use for defrost, and it runs the compressor unnecessarily (though I can add heat to combat it).
I've only noticed this in the past month or two, on this 10 month old F250. Maybe it's been doing it all along.
Thanks.
Thanks.
