1 - 20 of 25 Posts
1994 7.3 ( Non turbo ) Truck runs great, but now when it gets down to 1/4 tank, it dies. i have to floor it to get it started. I fill it up & it runs great. Could the float be bad in the tank ?
I doubt the float is bad, most likely scenario is the pick up foot has broken off. Common in these trucks and it usually shows up at about 1/4 tank.
The repair involves removing the tank, and adding diesel fuel rated hose. You make it longer than needed so it lays on the bottom of the tank, but cut the end like a fish's mouth so it can't get stuck and create a suction.
Since the pick up failing is common, its possible you lost both.
Do you commonly fill both at the same time? When my pickup feet failed they both failed around the same time, both were gummy as if the rubber had suffered attack by some kind of solvent. It happened to a lot of people around the same time, I speculated that they changed additives around then. No proof though :)
Raising the bed is easier than dropping both tanks, especially if you have a helper
The sending unit strainer and resister for the gauge both seem to fail at about 20 years. Sometimes the strainer is brittle and breaks off and sometimes it turns to mush(could be additives or bio fuel). New strainers can be had allover. LMC has them for $40. But if you are in there its best to do the whole sender for both tanks. Diesel senders are impossible to find but 5.0 and 7.5 senders can be had. Both of these engines are injected so they are 2 line systems. The 7.5 comes without a pump so you have to rig a pickup/strainer. The 5.0 only come with pump, pickup and strainer as an assembly. These pumps are pass thru pumps so the mechanical lift pump will continue to work, no need to hook up the electric pump. Both will have a 4 pin connector, you can get a 4 pin pigtail for $5. Make sure you get the Gas sender for your year truck as they changed the resistance a few times. And I also agree removing the bed is the way to go, even 5th wheel and goose necks installed.
Going to replace both sending units next week. Anything else I need to do ? Thanks
Better not buy any til make sure the sending units are bad.
Sticker shock, they are not cheap by any means, even if you can find them.
ebay for them, and check the prices, about $250 to 350 ea.
Yes, in fact often the sender is fine and the float is just full of fuel
Discussion Starter #16
So, if the sending units are fine & i see that the foot has broken off, I see in the comment above to add extra hose. Right ? without replacing the foot ? As you can see, I am no mechanic.
Make sure to use diesel rated fuel line, and cut the end in V's do it can't close up.
Sent from AutoGuide.com App
If the foot is non serviceable, toss it and replace with the hose.
1 - 20 of 25 Posts
