Hi,
I want to add a fuse to the passenger compartment fuse panel for a dash cam, I want to power with key on (otherwise I could drain the battery. Looking in the owners manual I see a layout of the fuses (see attachment) I bought a add a fuse at an auto parts store but just looking for advice which fuse to tap into. I suspect 10 Amp circuit should be fine. Just for easy access for me I was looking for a circuit below fuse 40. Any ideas / thoughts would be welcome. See signature block for truck information.
Note: I didn't want to plug into the cig outlet direct because I wanted to hide / keep clean the wiring.
I added the fuse section of the owners manual.
Do you have the up fitter switches? Those are powered with the ignition and are fused. If not a lot of the wiring. for them is in place so maybe someone can direct you where to tap into those at.
Find the PTO bundle under the driver's side dash. There is a KEY HOT wire that will run power when the key is cycled.
This. I used that wire for everything I hard wired, radar detector, phone charger etc. I saved the upfitters for things I needed to be able to switch.
What is the PTO wire fused at? One could build up a fused buss block for various items as you mentioned... You have me thinking now.
Cale
Its in the PTO bundle, but not specifically for PTO. I think it was blue with a white tracer. If memory serves it was nto a whole lot, 5 or 10 amps maybe? More than enough for my phone and radar detector, but not for say an inverter or anything. You could use it to pump a relay and feed your fuse block with that...
For anything that would draw some decent amps (IE light bar) I would use the KEY HOT feed to activate a relay feeding off the battery. To use it o power 1-2 AMP draw it's no problem to wire it direct.
I'd have to research the PTO wiring stuff to better understand the AMP rating of the KEY HOT White w/Blue tracer. EDIT: Owner's manual shows a 10A fuse.
