1 - 8 of 8 Posts
the difference between OEM and the after market is extraordinary.
do the after market work as well?
i have seen some people say the wiring is different.
i have 1997 7.3 power stroke
I have seen any post on how difficult it is to change out the selector valve
I have used a couple of the $80.00 aftermarket ones from O'Riley Auto parts and never had any issues. They lasted several years / miles and were doing fine when I sold the trucks. I have no idea if they are still working - now - several years later.
thanks
the price difference is so much I thought I might be missing something
Bought the after market
any suggestions on the install?
I would think the fuel tank and diesel spills would be the worst part
thanks again
Clamp off the hoses from the tanks or fuel will run out before you get the hoses off the old unit - and on the new one.
(I used 2 pairs of vice grips - tighten them "just" enough to smash it closed - don't over tighten!!!! there is no pressure on the lines - gravity siphon is all you have to stop)
Make sure you get the RIGHT HOSE to the RIGHT NIPPLE - make sure the change over is exact - or it will cause problems.
Discussion Starter #5 (Edited)
it seems that the replacement valve 3/8 valve and 5/16 are reversed?
looking at the clips that came off of each port.
does this sound correct?
i would think think that each hose will only fit the correct port
did you encounter this?
I would think that by taking off two hoses at a time starting with the top and replacing them to the new
selector valve this would stop any confusion. Not much play in the hoses.
Am i correct to assume so?
I never had that issue. Are you sure you are matching them up exactly?
However - it may be the particular brand of valve...?
The individual tank "send" and "return" lines must be matched from the front of the valve - to the back of the valve. There should be 4 ports / lines on the back of the valve and 2 ports / lines on the front.
The 2 on the front go to the motor (fuel pump and return - not sure of which is which...)
From my memory - I can't remember which of the 4 ports goes to which line on the back - (front tank suction and return - - back tank suction and return.
Discussion Starter #7
Thank you for your time.
I over complicated this, always when doing something for the first time.
It is a pain in the _ss. Ford could have moved it up the rail 12 inches forward.
that would have given all the room needed.
It was just a pain to get to every connectors to pinch them so I just disconnected and connected.
Yes I am soaked with diesel. But it is done and it works.
symptoms for any following:
1. switched tanks
all fuel gauges went past full no air conditioner
disconnected tank selector valve air conditioner works
2. bought after market selector valve (Orion) ~$70 works great direct fit
NAPA carries the clip for the fuel lines
Thank You for Your Time!
sometimes you just have get dirty and do it.
1 - 8 of 8 Posts
