I did a few tests and here nare the results
KO(OK) [14:58:53.190] KOEO Injector Electrical Self Test has been started
(WARN) [14:59:06.364] Test completed, found DTCs: P1293, P1294
(OK) [14:59:29.631] KOEO Output State Self Test has been started
(WARN) [15:01:34.933] Test completed, found DTCs: P0562, P1661, P1280, P0603, P0344, P1212, P0237, P1211
(ERR) [15:02:53.032] KOER Switch Self Test has been cancelled by operator
(ERR) [15:03:06.845] KOER Cylinder Contribution Self Test has been cancelled by operator
(OK) [15:03:19.172] Key On Engine Off On Demand Self-Test has been started
(WARN) [15:03:22.258] Test completed, found DTCs: P0475, P1293, P1294
(OK) [15:03:38.200] Read system monitor status has been started
(WARN) [15:03:38.224] Malfunction Indicator Lamp (MIL) Status: On
(WARN) [15:03:38.225] Misfire monitoring: Not supported
(WARN) [15:03:38.225] Fuel system monitoring: Not supported
(WARN) [15:03:38.226] Comprehensive component monitoring: Not supported
(WARN) [15:03:38.227] NMHC Catalyst monitoring: Not supported
(WARN) [15:03:38.228] NOX/SCR Catalyst monitoring: Not supported
(WARN) [15:03:38.228] Boost Pressure monitoring: Not supported
(WARN) [15:03:38.229] Exhaust Gas Sensor monitoring: Not supported
(WARN) [15:03:38.230] PM filter monitoring: Not supported
(WARN) [15:03:38.231] EGR and/or VVT System monitoring: Not supported
(OK) [15:03:45.468] Test completed successfully, no errors found
(OK) [15:03:52.910] Mode 6 - Test Results for Specific Monitored Systems has been started
(ERR) [15:03:53.564] Test completed, malfunction detected
Looking at my data as i try to start,
IPR% jumps to 54.9% and stays there as i crank
ICPV psi bounces really fast between 48 and 370 or so?
ICP psi jumps up and stays around 350-370 and stays until after a bit it jumps to 2400
Engine RPM's are right around 170+/-5
Also, when the ICP reading jumps to 2400, the IPR% drops to35.55 and stays there.
The fuel banks 1 and 2 read a constant -100
I hope someone can PLEASE make heads or tails freom this info????
