The system has two high pressure (small diameter) pipes. The first runs from the compresser to the upper fitting of the condenser. The second runs from the lower condenser fitting via the orifice to the evaporator. My question is; after the AC has been on a while should there be a significant or slight difference in temperature between the two pipes?
