Hello People, Is there a way to bleed the power steering system on these trucks ,has anyone done it. Thanks in advance.
Just have to crank the wheels from one side to the other while applying the brakes. Be careful the fluid will foam up when you are doing this, but this basically how you do it. If you can jack up the front end then it is a little easier but not really necessary.
Thanks I give it a try ,is there a way to flush the system. Thanks again
The accepted way is to remove the non-pressure hose from the brake hydroboost and just rooting it to a bucket. Then have somebody tap the brakes while it pumps out and you keep topping up the power steering reservoir. Not great but most do it this way. There is a utube video on it.
The video is for a 6.0 but they all are basically the same system. The 6.4 will just be more work because everything is so packed in. Let us know how you make out.
Just finished the flush out had the wife on the brake pedal, not hard with two people and the color of the fluid showed it did need to be done. Thanks again good information.:grin2:
Hi another thing I did notice that the fluid did not foam up or even bubble, doesn't it get hot . Thanks
