If you’re looking for more airflow than you’ll ever need and outstanding filtration, then this is the filter for you. AIRAID introduces their HUGE Premium Air Filter rated at over 3,900 CFM with deep pleats to capture more dirt and debris! The filter is 12” high with a huge 6” flange in either oiled or non-oiled filtration technology. Each filter also comes with a specially designed threaded end cap for added support. This filter is perfect for those looking for MASSIVE AIRFLOW!!!
• Perfect Filter for High Air Flow Applications
• Huge One Inch Thick Inlet Flange, Designed to Stay Put
• Heavy Duty Threaded End Cap Support
• P/N # 700-499 (Oiled) Premium Filter
• P/N # 701-499 (NON-Oiled) Premium Filter
How bad do these hurt the wallet?
Not to to bad.
Has this been TESTED IN THE DUST?
How has this air filter been tested in actual dust flying in the air conditions? A controlled test with a measured amount of dust in the air
and directed at the filter should be telling, too.:ford:
Discussion Starter #6
Hello 1997 FORDF350PS,
The Filter has been tested in a ISO5011 performed by the Southwest Research Institute.
Test Results : http://www.airaid.com/smax_flow_test_page.html
Thanks,
David
