I was installing some aftermarket gauges the other day. I removed the
dash piece that goes around the instrument cluster,radio, headlight switch, etc. I got the gauge installed and ran the power wires under the dash and reinstalled the dash piece. I installed a boost gauge so before I wired up the power to it I wanted to make sure everything was good. I turned on the key and fired it up. Now the airbag light blinks for about a 1 minute and then stays solid. I noticed that the passenger side airbag switch wont light up the off light anymore when dissabled.
So I made sure the plug was on the switch completely.
I have also disconnected the battery for several hours and tried again.
Im not sure what happened.
Anybody had this before.
