Well, I finally installed the Airdog in my van. It took two of us seven hours of steady work to do the in-tank mods, harpoon, and install the Airdog. This did not count the prep work I did earlier by having a custom mounting bracket fabricated and powder-coated.
Having already installed an Airdog and in-tank kit on my truck, plus having dropped its tank twice, this was an easy and straightforward installation for me. The airdog is located below and slightly forward of the filler neck. This is the only stretch of frame that is smooth and free of hardware sufficient to bolt a ten-inch long flat plate on. Dropping the tank seemed easier on the van than the truck. Perhaps it was because I had driven thirty miles with the low fuel light on, or perhaps it was because I backed the rear wheels up a set of ramps, instead of having it on a lift, or the back axle on a lift, as I had done when I dropped the tank from the truck.
I highly recommend a bone creeper with 5 or 6 inch wheels. The only thing you wish for with one of those is a parking brake! /ubbthreads/images/graemlins/laugh.gif
I intended to take some pictures of my custom bracket, but that part of the program did not work into the schedule. There is a set of 1/2" holes in the frame that is 7.5" apart. They are a little above the center line of the frame rail. The bracket is a box, with a back plate for mounting to the frame, a 3.25" offset from the frame to clear the parking brake cable & yoke, and a 1" drop for the front plate to lower the Airdog away from the body.
Harpooning was a cinch. The vent line is a rubber hose that connects via a swivel connector to a 90 degree elbow formed of 1/2" steel tubing. The tubing is brazed into its place in the circular cover plate. It protruded below the cover plate about 2.25" I cut it off as close as I could with a hacksaw. It used to take 5.5 gallons after shutoff, now it takes1.7 /ubbthreads/images/graemlins/biggrin.gif I'm an extra-super-happy camper about that!
The wiring was easier, now that I have a butane-powered soldering iron. I mounted the relay to the cable tray in the back of the hood opening, I soldered the black trigger wire to the red/green wire that goes to the top connector of the OEM pump. I tied the relay power to the power box next to the fuse box, and the ground to the groundstrap connection point at the back of the hood opening.
I used a 1/4" amber LED to the left of the steering column in place of the emergency search beacon that came courtesy of the nice folks at Eckstam for a water in fuel light. It's the same kind I put in the truck, so if you search back in my posts you'll (eventually) find a link to it. Or maybe its in my links? I don't remember.
One of the interesting items was the extended return portion of the ITP in-tank kit. It didn't work, because the van's return doesn't point straight forwards, it points left and slightly downward. Also, the van's metal tank is baffled, with a low kind-of-circular wall surrounding the pickup. I made a few bends to the kit's stainless return tube, and tried a few configurations, but I ended up using a length of rubber hose instead. I was willing to try adding some bends to try to clear things, but I didn't think I could un-bend the stainless tubing without cracking it. I used a 1.5" straight piece of the tubing to adapt the OEM orange rubber check valve that had been on the end of the return line to the end of the new, improved, extended return hose.
The airdog made the idle quieter, but didn't seem to do much for mid or high range. Maybe its a little smoother. Also, maybe I don't have all of the air out of the system yet.
In the back of my mind I wonder if this mod is somewhat handicapped by the factory pump/mixer unit. Perhaps I should consider bypassing the pump/mixer with the return line, and send it directly back to the tank. I'm going to ask about it on the 6.0 upgrades and aftermarket.
Dennis, if you're out there, I don't think this kit came with an extra filter like my truck's kit did. /ubbthreads/images/graemlins/shrug.gif
