1 - 11 of 11 Posts
A little help please. I have finally lost a majority of my hub end caps and will replace with the alcoa product. What I need are the part numbers for: lugs, lug covers, hub cover. I have a 97 F250 4x4 with lock-out front hubs. Thanks!
Part #s are as follows, thanks to dtosh.
2 - #3167 Front Center Caps for 4x4
2 - #8167 Rear Center Caps (Alcoa emblem on center in blue or black)
32 - #5916 Steel Lug Nuts
32 - #78 Lug Covers
Go to: www.alcoawheelaccessories.com
I ordered mine directly from Alcoa and had the parts in 2 or 3 days. Go for it....you won't be sorry.
John
LOOK HERE
I just lost my first rear center cap after having factory tires replaced and found this old post with what seems like a good solution. I do have 3 follow-up questions to anyone who has done the Alcoa conversion.
1. Do the lug nuts actually need to be replaced?
2. There is a link to purchase Alcoa accessories above but the site is under construction. Where is the best place to purchase these accessories?
3. Are the wheels on the 95-97 trucks actually made by Alcoa?
You can try the center caps that JC Whitney has to offer. Someone I know has them on his truck and the fit over the lug nuts. As for price /ubbthreads/images/graemlins/shrug.gif, you will have to check with them. I don't like the looks of the factory caps or the one from JCW, so I went with the Alcoa set. I like them a lot and they make the wheels look so much nicer, IMHO. Good luck, as the center caps seem to always be an issue on our trucks. Matt
the alcoa page is under construction
How much are these new center cap pieces?
Hud
1 - 11 of 11 Posts
