1 - 14 of 14 Posts
Ok I almost have $300+ saved for Gauges what is good for around that price? I was thinking of the Z series from AutoMeter is there anything else I should be looking at? I want 3 w/ pillar pods what is a good brand and series for as close to $300-325????
i found a set on ebay with the boost -trans -exhaust temp ,and comes with the mounting pod for 190.00 pus shipping @30 for a total of 220 bucks . they have a push button on the gauges to choose from 7 different colors . the wires for the power need to be crimped from the gauges down to one then to the power source ,while the sensors have plugs at the end and are more than long enough to reach the mounting pod with a need to loop the remainder , the lights come on when the key is turned on and the color you had set stays ,unless you choose a different one . they are working well for me and look good as well, they are from glowsift .com . but on ebay the price usually is lower
You seem to be down on the AutoMeter whats the problem with them???
No, I'm not down on Autometer. They make a bunch of styles and price ranges, including cheap junk, really-good-but-expensive stuff, and some decent stuff. If you find an Autometer style that includes a 270º sweep for the boost and tranny temp gauges, easy-to-read-at-a-glance face, color-coded pre-turbo pyrometer dial, match the stock gauges so close that folks think Ford must have installed them, and less money than the ISSPRO EV, then get them.
Well that sounds a bit better than your first reply, kind of hard to hear one say do it right the first time buy this or that brand when there are several that get the job done just as well.
You seem to be down on the AutoMeter whats the problem with them??? I have had them in my truck for the last 6 years, can't find anything to make the comment do it right and get ISSPRO
I first bought Autometers and a pillar mount. When I installed the pillar mount I didn't like it. I removed it and bought a three gauge under dash mount. I couldn't read the gauges at night mounted in that location. Perhaps I could have if my eyes were still young. I sold the autometer gauges and bought Dipricol Optix because a couple of TDS vendors told me they had the best lighting of any brand. They match well and I can read them.
Smokey, I am new to this and was wondering what the advantage of the 270 sweep has?
You want to be able to read the gauges at a glance. When the gauges are nearing the redline, you are too busy driving to be staring at gauges. So you want the area around the redline to be spread out and very easy to read and interpret. For tranny temp, the red line is 225º, so you want the area between about 200º and 230º to be very visible and easy to tell the difference between 220º and 225º. For boost, the red line with a stock turbo is 25 PSI, so you want the area between about 20 and 25 PSI to be big enough easily tell the difference between 22 and 24 PSI.
Many gauges have only a 90º or 180º sweep, crowding the the numbers together so it's hard to tell the difference in a small change. 270º spreads out the numbers so you can crowd the red line without exceeding the red line - and at a glance - when you are towing and busy dodging traffic and outrunning the Dodge to the top of the pass. :)
The ISSPRO pre-turbo color-coded pyrometer is not only 270º, the color coding makes it even easier to read the gauge at a glance so you can maintain between 1,200º and 1,250º EGT while climbing the mountain, dealing with traffic, and keeping an eye on that Dodge.
So if you are right on the edge of 1250° and that Dodge is creeping up on you, do you let the Dodge pass you or do you go past 1250°.
Discussion Starter · #11 ·
Smokey, YOU DA MAN!!! that was a very concise and easy to understand answer. I am always a function over form person, so the look ain't that big a deal but getting home in one piece is...
it looks like I will be saving up a few extra bucks before ordering. So it's the ISSPRO EV?
Depends on how far it is to the crest. If it's only a quarter-mile or so, then I'd probably mash down a bit harder to creep up to near 1,300º EGT. But if I'd have to stay at 1,300º for more than a few seconds, Then I'd probably back off to 1,250º and let the Dodge guy melt his pistons. :(
It hasn't happened yet. ;)
Discussion Starter · #14 ·
I ordered a set of the ISSPRO last week now just can't wait until wed when they are supposed to get here... It is almost as painful as the 10 day wait for gun...
1 - 14 of 14 Posts
