1 - 10 of 10 Posts
Not sure if I'm asking in correct forum. I did a search but no recent postings. I'm looking to get some kind of app that is like the torque pro, to read my early 1999 E350 (van) Is the Torque Pro the best deal going or is there better ones for the buck? And do they show more sensors now? Will I be able to get all parameters? such as fuel pressure? Tranny temp? LPOP ? HPOP? EOT ? ECT? etc...
Also are some more user friendly than others?
Discussion Starter #2
No one? using these?
I use the Torque app. Don't have experience with any others. I also use a laptop, Forscan and an OBD2 cable to check other parameters that Torque can't.
The Scangauge 2 is in the near future.
Have a scan gauge original . Not enough info? What does your torque pro not show?
Scangauge 2 will give you EOT and Trans temp, but can not give you ECT and fuel pressure because there is no sending unit for those. So you would need to use a gauge and install a sending unit because IIRC the ECM does not read for those so a OBD app will not work for those parameters. HPOP and LPOP I am not sure about.
Discussion Starter #7
OK, thanks, thats what I need to hear. Does the Torque Pro show LPOP & HPOP ?
HPOP and ICP are the same I think. LPOP does not have a sending unit if I remember correctly. Scan gauge 2 will read ICP and IPR. and much more.
Here's the Scangauge page listing the xgauges for our trucks. Some of the general Ford / Lincoln gauges work, but there is also a list of 7.3 specific xgauges further down the page. Some things can't be done, like jleedog said. You need to install senders and separate gauges for LPOP, Coolant, and EGT.
https://www.scangauge.com/support/x-gauge-commands/ford-lincoln-mercury/
Discussion Starter #10
Andrew G, thanks, good info. I'll have to figure what version I have & maybe mail back for the upgrade.
1 - 10 of 10 Posts
