I just replaced my FICM, batteries, and alternator about a month ago and this morning the voltage reading on my scan gauge dropped from 13+ to 11.9-12. Then it stayed at 11.9 and the battery light came on. Am I seriously going to have to replace the alternator again? What would cause this to happen?
That's not likely the alternator causing that. You're seeing battery drawdown from the GPs. I'd put my money on one or more batteries being weak. If you're putting out 13.5-14V going down the road once its warmed up the alternator is doing its job.
Thank you for the reply, but did you read the post? "The voltage reading on my scan gauge dropped from 13+ to 11.9-12." Indicating that the alternator was out. I had the alternator bench tested and it was indeed bad. My question is what would cause it to go bad in less than a month? By the way how much money were you putting down? haha
Yes, I read it, but you are misunderstanding what you are seeing. The amp load when starting a 6.0 and while the GPs are lit, which is for several minutes after starting, is extremely high. It is too high for a stock output alternator to fill the void created by the drawdown of the batteries. So what you are seeing is the load draw the batteries down to a degree for which the alternator cannot compensate. Once the GPs go out the alternator can fully recharge the batteries, which is why you see the reading go back up. A weak battery exacerbates this effect.
This is why 6.0s seem to go through batteries much faster than other vehicles. My stock batteries lasted all of two years. I then switched to Interstate Megatron II batteries from which I typically get 5 years. My stock alternator has 194k on it and still does the job.
An option is to swap in a higher output alternator like one from DC Power, but they are spendy ($300+).
Still another option is to upgrade the charging cabling from that alternator by adding a 1 gauge wire from the charging post to the + terminal on the RH battery, and add a 1 gauge ground from the alternator case to the chassis ground lug on the crossmember. I did that upgrade about 74k ago.
Reactions: TurboThrill
