Alright, so I've seen a lot of threads with issues around starting, and I've tried to use the advice posted in all of them, but my results have been less than stellar. Here's my story.
I've got an 89 F350 non turbo with 148K on it. Transmission was rebuilt before I bought it the truck, and once running she's sound as a pound. Since I bought the truck though, starting has been an issue. The previous owner said it needed a new GPC, so I replaced that and the GPs (the tip had broken off in the #2 cylinder, but I wasn't sure if it happened while driving or during the swap... so I paid to have the head pulled. There was a tiny piece of it sitting on top of the cylinder, smashed flat, no real damage to the block or piston) Now I get the proper cycles from the GPs. Still wasn't getting reliable starting at all, and I noticed that the starter RPMs seemed slow. Had both batteries tested, both 850 CCA and 12.6V. Pulled the starter and had it tested (all good), and ran all new battery cables, cleaned all contact/ground points and replaced hardware as necessary. Turned the key, WTS was normal but once it turned off turned to start and... nothing. So I tried jumping the posts on the relay on the fender and it cranked! Figured this meant the relay was bad, so I replaced it... and lost all power to the dash. So I put the old one back on, jumped it while opening the throttle manually and she came to life! I took her for a spin after letting it warm at idle, drove for 20 minutes and all was well. Parked and shut off, Let her cool off for a minute then turned the key and she started right up! That was last night. At about noon today, I went to start the truck, WTS, GPC, all sounded right and she cranked with good RPMs, but wouldn't start. After a couple tries with 20ish seconds of cranking, the starter RPMs nosedived. I figured the batteries were drained, and so I took them to get tested again (along with the alternator for peace of mind) and all was well. Reinstalled everything, along with a new voltage regulator when I got back from Advanced Auto and still had low starter RPM. The batteries are getting a charge tonight, but I got to know, am I fooling myself thinking that this is a power issue? Do I need to start looking at fuel supply and air intrusion? Fuel return lines were all replaced when the head got pulled, but I am at a loss on what I need to do to get this truck road ready. I've already learned so much from these forums, I really appreciate you experts.
