Not long ago for the wife we picked up an all stock 2004 Excursion with 70,000 miles. I installed a Scan Gauge II to monitor temps. I flushed the cooling system with Restore, Restore+, plenty of flushes between the treatments and after with distilled water and then used Zerex ELC to refill the system. I also installed a coolant filter at that time.
Once the engine gets up to temp. the ECT runs between 185 to 198 depending on outside ambient temps which have been in the mid 90 degree range. This was the case before as well as after the coolant change. Driving around town the EOT runs about 8 to 12 degrees hotter than the ECT, which once again was the case before the flush & coolant change and continues to be the case after the new ELC.
Yesterday we exercised the engine on the highway. The ambient air temp was in the 90 degree plus range. Running about 80 MPH for 30 or so minutes the ECT was up to around 195 degrees. The EOT climbed and held around 18 degrees hotter hovering around 213 degrees. I don't think it ever got hotter than that and at times was a few degrees cooler bringing the delta back down to 15 degrees or a hair less. When we came off of the highway and drove at about 55 mph with some stop lights now and then along the way, the ECT dropped a couple of degrees and the EOT dropped much more so showing only 8 to 12 degrees hotter than the ECT.
Am I looking at a problem now or in the near future in this regard?
