1 - 19 of 19 Posts
Any 6.4L owners use an app on their smartphone or tablet called Torque Pro??? Its on the Android market and works through a wireless OBDII device.
Torque Pro
I have torque pro and a cheap bluetooth OBDII adapter I got from ebay, it works really well. I use it with a companion plug in app for torque called "torque scan" it shows all the raw data from all the sensors the OBDII scanner can see with the only downside being some of the measurements can't be changed from metric to english units. But its a really neat app and come in handy for scanning codes and clearing if necessary. If you have any specific app questions let me know and I can experiment.
How are you monitoring EGT and FP? Old style gauges or through a different aftermarket monitor?
Hey Folks:
Didn’t have the Torque App for my 6.4L (wish I had). Not sure why you can’t change from Metric to English, it should be a matter of changing the settings, if not you can change the equation? Canada is Metric and I’m old and prefer English.
That said, the App is really a code scanner and most people like us want to use it as a monitor and this is where the learn curve gets a little steep. I monitor the EGTs to know when I’m in Regen and have been testing on my 6.7L to get a Regen status light.
I believe the 6.4 has 3 EGT sensors and the PIDs I posted below could be corrector at lease a starting point?
EGT 1 = 22096D
EGT 2 = 220992
EGT 3 = 221171
Good Luck
Discussion Starter #6
I was just wondering because on my 6.0 we don't have factory sensors for FP or EGT and I have found an aftermarket device that allows you to add these sensors to Torque Pro through OBDII port. They're through a company called PLX and the bluetooth dongle is called a Kiwi 2 BT and they can be connected to up to 32 Sensor Modules. I'm wondering if anyone has ever heard of these?
Sorry didn’t notice that you had a 6.0L, I did read a link about adding a after market module that would allow you to connect sensors to it and in turn allow Torque to access the data through a CAN BUS (OBD port) and make a custom PID to display it. If I find the link, I’ll pass it on. I’m new to all this and still trying to understand the hardware and software. Please understand that I’m learning it for interest and it is a steep learning curve for me, folks without knowledge of software and hardware can get over whelmed.
6.4 Powerstroke PIDs for the Torque Pro App
I'm trying to make a complete list of the extended PIDs for the 6.4L Powerstroke diesel. This is what I have come up with so far by experimentation.
NOTE: You must have the Ford Specific PID set provided by Torque already loaded.
I would appreciate help completing the ones that are not marked as "Testing Complete: Yes"
I will make revisions to the list as testing progresses.
Here we go!
6.4 Powerstroke PIDs for the Torque Pro App:
PID: 2209d4
Long Name: 6.4 Accelerator Pedal Position
Short Name: Pedal
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: A/2
Header: Auto
Notes:
PID: 2216a8
Long Name: 6.4 Ambient Air Temp.
Short Name: Amb. Air
Min.: 0
Max.: 120
Scale: x1
Units: °F
Equation: (A*256)+B
Header: Auto
Notes:
PID: 221172
Long Name: 6.4 Battery Voltage
Short Name: Battery
Min.: 0
Max.: 100
Scale: x1
Units: Volts
Equation: A/16
Header: Auto
Notes:
Testing Complete: No
PID: 221624
Long Name: 6.4 Cylinder Head Temp.
Short Name: Cyl. Head
Min.: 0
Max.: 100
Scale: x1
Units: °F
Equation: (((A*256)+B)*1.999)+32
Header: Auto
Notes:
PID: 22fd8a
Long Name: 6.4 Dist. Since Last Compl. Regen
Short Name: DSLCR
Min.: 0
Max.: 10000
Scale: x1
Units: Miles
Equation: (((A*256)+B/10)*0.621371192
Header: Auto
Notes: This is probably not the correct PID
Testing Complete: ?
PID: 22116c
Long Name: 6.4 DPF Back Pressure
Short Name: DPF BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Equation: (((A*256)+B)*0.03625)*0.145
Header: Auto
Notes: Equation? Sensor spec range is 0-12 psi.
I added *0.145 to convert from kPa to psi
PID: 220966
Long Name: 6.4 DPF Regen Status
Short Name: Regen
Min.: 0
Max.: 128
Scale: x1
Units: on/off
Equation: A/128
Header: Auto
Notes: Result will be a 0 or a 1
PID: 22c974
Long Name: 6.4 DPF Soot Load
Short Name: DPF Soot
Min.: 0
Max.: 100
Scale: x1
Units: #
Equation: (((A*256)+B)+8192)/1000
Header: Auto
Notes: Just a raw number at this point. Needs more work.
I divided by 1000 just to get a smaller number.
PID: 22115f
Long Name: 6.4 Turbo Inlet Temp. (EGRT1 or A)
Short Name: Turbo In
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Equation: ((((A*256)+B)/10)-40)*(9/5)+32
Header: Auto
Notes: Equation?
PID: 221161
Long Name: 6.4 EGR Inlet Temp. (EGRT2 or B)
Short Name: EGR In
Min.: 0
Max.: 600
Scale: x1
Units: °F
Header: Auto
Notes: Equation?
PID: 2209fe
Long Name: 6.4 EGR Valve Position (% open)
Short Name: EGR %
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: ((A*256)+B)*0.003052
Header: Auto
Notes: Equation?
PID: 220991
Long Name: 6.4 EGT11 Post Turbo (pre DOC) Temp.
Short Name: Post Turbo
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Equation: (((A*256)+B)*(9/5))-40
Header: Auto
Notes:
PID: 220992
Long Name: 6.4 EGT12 Post DOC (pre DPF) Temp.
Short Name: Post DOC
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header:
Notes:
PID: 221171
Long Name: 6.4 EGT13 Post DPF Temp.
Short Name: Post DPF
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 0105
Long Name: 6.4 Engine Coolant Temp.
Short Name: Coolant
Min.: 0
Max.: 300
Scale: x1
Units: °F
Equation: ((A-40)*(9/5))+32
Header: TCM
Notes:
PID: 221310
Long Name: 6.4 Engine Oil Temp.
Short Name: Eng. Oil
Min.: 0
Max.: 300
Scale: x1
Units: °F
Equation: ((((A*256)+B)/100)-40)*(9/5)+32
Header: Auto
Notes:
Testing Complete: ?
PID: 221445
Long Name: 6.4 Exhaust (manifold) Back Pressure
Short Name: Exh. BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Equation: (((A*256)+B)*0.03625)-BARO()
Header: Auto
Notes: Equation? Sensor spec range is 4-90 psi.
PID: 221674
Long Name: 6.4 Transmission Fluid Temp.
Short Name: Trans. Fl.
Min.: 0
Max.: 300
Scale: x1
Units: °F
Equation: ((A*256)+B)/8
Header: TCM
Notes:
PID: 221440
Long Name: 6.4 Turbo Boost Pressure
Short Name: Boost
Min.: 0
Max.: 40
Scale: x1
Units: psi
Header: Auto
Notes:
Thanks for reading.
Ollie972:
Thanks for all the work, wish I had Torque Pro when I had my 6.4L. Did you happen to find PIDs for the 6.7L
Sure, the 6.7 PIDs are easy to get.
The following forum address is good to get you up and running with the 6.7 PIDs:
Torque Pro Ford 6.7L Extended PIDs - Page 3 - Ford Truck Enthusiasts Forums
I don't know if it will show as a link, but you can type it in on the address line of your browser.
Thanks, that Thread happens to be the one I started. I was wondering where you got the PIDs for the 6.4 and maybe there were some for the 6.7L there? Good work, I know how hard it is to find them.
Good Work.
Here we go!
PID: 2209d4
Short Name: Pedal
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: A/2
Header: Auto
Notes:
PID: 2216a8
Min.: 0
Max.: 120
Scale: x1
Units: °F
Equation: (A*256)+B
Header: Auto
Notes:
PID: 221172
Short Name: Battery
Min.: 0
Max.: 100
Scale: x1
Units: Volts
Equation: A/16
Header: Auto
Notes:
PID: 221624
Min.: 0
Max.: 100
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 22fd8a
Short Name: DSLCR
Min.: 0
Max.: 10000
Scale: x1
Units: Miles
Header: Auto
Testing Complete: ?
PID: 22116c
Short Name: DPF BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Header: Auto
PID: 220966
Short Name: Regen
Min.: 0
Max.: 128
Scale: x1
Units: on/off
Equation: A/128
Header: Auto
PID: 22c974
Min.: 0
Max.: 100
Scale: x1
Units: #
Header: Auto
PID: 22115f
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes: Equation?
PID: 221161
Short Name: EGR In
Min.: 0
Max.: 600
Scale: x1
Units: °F
Header: Auto
Notes: Equation?
PID: 2209fe
Short Name: EGR %
Min.: 0
Max.: 100
Scale: x1
Units: %
Header: Auto
Notes: Equation?
PID: 220991
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 220992
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header:
Notes:
PID: 221171
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 0105
Short Name: Coolant
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: TCM
Notes:
PID: 221310
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: Auto
Notes:
Testing Complete: ?
PID: 221445
Short Name: Exh. BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Header: Auto
PID: 221674
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: TCM
Notes:
PID: 221440
Short Name: Boost
Min.: 0
Max.: 40
Scale: x1
Units: psi
Header: Auto
Notes:
Thanks for reading.
I am interested in info related to teh 6.4 dpf and regen - thank for your work on this.
I am also looking at openxc which is an open development facility for creating apps related to obtaining info from can bus via odb port.
I don't have an apater but will probably order one over the break.
Hopefuly I can help with testing.
johnh...
Adapter Warning
To all concerened,
If you are buying a bluetooth adapter for Torque Pro, don't get the vgate icar2! It causes random faults on the can bus. Today it caused a turbo over pressure fault (note: there was nothing really wrong with the turbo). A friend of mine also had the same fault on his 6.4 today. So, I guess you get what you pay for. I will probably end up getting the adapter I was originally looking at, which is the OBDLink MX.
Ollie.
I've been trying to figure out if the 6.4L pre turbo Sensor is for capturing EGT or BP or something else? What I need is a OBD BT adapter and the right App or program to display the EGT as a gauge so when I'm towing my RV I can monitor the temps and protect my engine. This thread seems to be all about that. Is the Torque Pro App and the OBDLink MX the right combination to do this? And what was that about the Ford specific PID's? where do you get those? Any clarification is appreciated.
I didn't know about the Torque Pro App when I owned a 6.4L. I do use it with my 6.7L.
The Torque App is for an Android phone, not Iphone.
There is 3 exhaust gas temperature sensors on the 6.4L and it looks that the poster above has found some of the Ford PIDs specific to the 6.4L.
It seems that the poster can monitor oil, coolant, exhaust and transmission temperatures among other sensors.
What you need?
Device that can run android OS (phone or tablet).
Torque Pro from Google Play or other App store.
https://play.google.com/store/apps/details?id=org.prowl.torque&feature=related_apps
OBD2 Bluetooth Adapter. The BAFX from Amazon works and is a lot cheaper then the obdink.
I'm now using the OBDLink MX Bluetooth version adapter. I had a problem with it not going int sleep automatically, but after a call to the manufacturer they told me how to do a reset on it and how to correct a setting in Torque and now it works. You need to put a check in the Torque setting called "ScanTool.net (OBDLink) Power Savings". Without doing this it will not go to sleep properly. I also found that I need to close the Torque app before shutting off the engine!
As far as what all the sensors are and such I would suggest searching the web for the Powerstroke 6.4L Bible and start reading.
In regards to your question about the pre turbo temp (PID 22115f on my list), that will be the hottest one, since it is right after the exhaust manifolds. One thing to note about this sensor is that it is not very accurate until a little while after engine start when it heats up a little, so don't be alarmed if it reads something like 140 degrees with a cold engine before starting.
this link talks about adding the basic Ford specific PIDs into the Torque Pro app: Ford 6.0L Diesel Extended PIDS for torque pro app. - Ford Truck Enthusiasts Forums
You need those in Torque Pro before you start adding the ones for the 6.4L or 6.7L.
Good Luck.
Latest list of PIDs for the 6.4
My experimental 6.4 Powerstroke PIDs for the Torque Pro App:
PID: 2209d4
Short Name: Pedal %
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: A/2
Header: Auto
Notes:
PID: 221172
Short Name: Battery
Min.: 0
Max.: 100
Scale: x1
Units: Volts
Equation: A/16
Header: Auto
Notes:
PID: 221624
Min.: 0
Max.: 100
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 22fd8a?
Short Name: DSLCR
Min.: 0
Max.: 10000
Scale: x1
Units: Miles
Header: Auto
PID: 220966
Short Name: Regen
Min.: 0
Max.: 128
Scale: x1
Units:
Equation: A/128
Header: Auto
PID: 22c974
Min.: 0
Max.: 100
Scale: x1
Units: #
Header: Auto
Notes: Use this raw number to determine your range then
create another PID for percentage (see next PID).
PID: 22c974
Long Name: 6.4 DPF Soot Load Percentage
Short Name: DPF Soot %
Min.: 0
Max.: 100
Scale: x1
Units: #
Equation: (((((A*256)+B)+8192)/1000)-45)/(57-45)*100
Header: Auto
Notes: My Soot Load range is about 45 to 57.
So, % Soot = ((Soot Load)-45)/(57-45)*100
PID: 22115f
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes: Equation?
PID: 221161
Short Name: EGR In
Min.: 0
Max.: 600
Scale: x1
Units: °F
Header: Auto
Notes: Equation?
PID: 2209fe
Short Name: EGR %
Min.: 0
Max.: 100
Scale: x1
Units: %
Header: Auto
Notes: Equation?
PID: 220991
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 220992
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header:
Notes:
PID: 221171
Min.: 0
Max.: 1800
Scale: x1
Units: °F
Header: Auto
Notes:
PID: 0105
Short Name: Coolant
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: TCM
Notes:
PID: 221310
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: Auto
Notes:
Testing Complete: ?
PID: 22116c
Short Name: DPF BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Header: Auto
Testing Complete: ?
PID: 221445
Long Name: 6.4 Exhaust Manifold Back Pressure
Short Name: Exh. BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Header: Auto
PID: 2216a8
Long Name: 6.4 Intake Air Temp.
Short Name: Intake Air
Min.: 0
Max.: 120
Scale: x1
Units: °F
Equation: (A*256)+B
Header: Auto
Notes:
PID: 221674
Short Name: Trans. Fluid
Min.: 0
Max.: 300
Scale: x1
Units: °F
Header: TCM
Notes:
PID: 221440
Short Name: Boost
Min.: 0
Max.: 40
Scale: x1
Units: psi
Header: Auto
Notes:
Olllie972:
Did to try the TPMS PIDs that was just posted in the 6.7L thread by another member? No sure if the 6.4L had its own TPMS module, but it is worth a try.
1 - 19 of 19 Posts
