I have a 2007 Ford F250 6.0 diesel. It seems I have had one problem after another and I am learning as I go. My latest problem has me at a loss and I can't seem to pinpoint the cause.
I've had the truck for about three years now. I've replaced the FICM, EGR cooler, cleaned the EGR valve, cleaned the turbo, replaced the oil cooler, replaced the head gaskets, and most recently I put a new alternator in it. It is still smoking! Not only is it smoking but there seems to be a loss of power. Just today, the start was difficult and that is when I found the alternator was bad. I recently took it to the Ford dealer for a diagnostic. They said the FICM needed to be replaced again... so I have put a second one in it.
1. So, one thing the dealer has in their notes is that during a power balance test, cylinders 3 and 7 dropped -20 RPM, and during a relative compression test all cylinders passed. Could I need new fuel injectors on 3 and 7?
2. The EGR test failed. I am going to replace this but could this be the cause of the white smoke (smells like unburnt fuel - not coolant) and the lack of power?
3. I noticed today that the turbo took a long time to kick in - do you think I need to clean it again (did so about 2 years ago)... or can one of these other issues be the problem? Maximum MGP was 3.44 PSI during test.
4. I checked the EBP sensor today - was clear, but did find a few wires that were exposed so I fixed those. When I started the truck again, I got a P0113 Air Intake Temperature Circuit. This is a new one. I cleared and it did not reappear.
In the last 3+ years of owning it, I have put less than 20K miles on it because it has been one thing after another. It has now 86K miles on it. I know these issues are all over forums but I have read them and still can't pinpoint what is going on.
Any help is appreciated. Thanks!
