cold engine sat overnight outside temp 32 degrees
before start:
intake air temp input = 32 deg
oil temp input = 30 deg
coolant input = 509.20 deg
after 1 min running coolant dropped to 11 deg
after 5 min idling:
intake air temp = 46
oil temp = 100
coolant temp 317
after 10 min idling:
intake air temp = 54
oil temp = 141
coolant temp = 491
injector control pressure:
600lbs @ 85 deg oil @ 700rpm
483lbs @ 145 deg oil @ 680 rpm
800lbs @ 145 deg oil @ 2000 rpm no load
rotational velocity:
#2 = .4
#3 = 2.5
#8 = 5
all others are 0.0
what does any of this mean?
what is spec on injector control pressure?
before start:
after 5 min idling:
oil temp = 100
coolant temp 317
oil temp = 141
coolant temp = 491
#2 = .4
#3 = 2.5
#8 = 5
all others are 0.0
