Autoglym Engine & Machine Cleaner is a powerful, water based, biodegradable degreaser which rapidly dissolves oil, grease and grime from your engine.
It is an incredibly easy to use spray on, brush and hose off product that will leave all of the metal, plastic or rubber components of your engine bay looking brand new with very minimal time and effort.
Make sure to cover up all of your electrical components such as your battery first to ensure you have a safe area to work on and to avoid any potential damage.
Working on a cold engine, first clear up and leaves and then spray the cleaner onto the engine and agitate with a brush to clear up and dirt and grime, working from the bottom up. Once your engine has been fully cleaned, rinse away the product with a low pressure hose and you should be left with an engine bay that looks good as new.
After cleaning the engine, use Autoglym Vinyl & Rubber Care to complete the look. Simply spray the product onto the wet surfaces of the engine, close the hood and allow it to dry. This will provide the plastic and rubber of your engine with a protective coating to ensure its stays clean as well as restoring colour to them.
Follow us
Autoglym Canada
Autoglym Canada Blog
Official Autoglym Canada Facebook
Official Autoglym YouTube
We are here to help you
If you require car care advice, or are unsure on the right Autoglym product to use, please leave a comment or visit www.autoglym-canada.com for more information.
