Plastic, vinyl and rubber components in your car are susceptible to the sun, which means they can fade, dry or even crack over time. Autoglym Vinyl & Rubber Care is a spray-on product. Its formula of blended polymers and emulsifiers works to gently clean, condition and protect these interior surfaces, forming a barrier against the effects of the sun while restoring original surface colour back to them.
Simply spray Vinyl & Rubber Care onto clean surfaces and wipe over with a clean cotton or a microfibre cloth to reveal a beautiful protective sheen. It can be applied to give a high or low sheen and leaves you with a fresh lemon scent.
Vinyl & Rubber Care can be applied to protect interior surfaces such as fascias, instrument panels, door and seat facings and door shuts. It can even be applied to rubber door seals to prevent sticking in freezing weather. Vinyl and Rubber Care is also great to use on your engine compartment components. After treating it with Autoglym Engine & Machine Cleaner, simply spray Vinyl & Rubber Care over a wet engine and leave it to dry.
Autoglym Vinyl and Rubber Care will leave your car's interior surfaces protected and restored to a beautiful sheen.
Follow us
Autoglym Canada
Autoglym Canada Blog
Official Autoglym Canada Facebook
Official Autoglym YouTube
We are here to help you
If you require car care advice, or are unsure on the right Autoglym product to use, please leave a comment or visit www.autoglym-canada.com for more information.
