1 - 8 of 8 Posts
The gauge came with a T fitting that is 3/16 by 1/4. The rubber hose the leads to the MAP sensor is 1/4" so the T won't work.Should I call Autometer for another T or is there another way to install this? /ubbthreads/images/graemlins/shrug.gif
Discussion Starter · #2 ·
anyone?
I got my T from the home depot /ubbthreads/images/graemlins/grin.gif. Im sure any hardware/plumbing supply will have it. Good luck! /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif
I put mine in the intercooler tube. Right in the plastic. Drilled and tapped the plastic. My theory was that this would be a rather cheap replacement, rather than the metal elbow as many people have done. I didn't put it in the map sensor hose as I had heard that several people would get a vibrating needle. My gauage even had a disclaimer in the package about this.
Do it the easy way. IAH Delete w/ boost fitting.
Your post says IAH but your sig. says AIH, either way,what's that? /ubbthreads/images/graemlins/shrug.gif
It's AIH (Air Intake Heater). Look here; <font color="blue">AIH plug w/ boost fitting</font> for the item he is talking about, 4th item down. Look in my Truck Pic's under mods purchased from vendors to see what the factory AIH looks like and the restriction it supposedly causes.
Thanks for the info,but I'v got the 6L so I don't think it's the same /ubbthreads/images/graemlins/confused.gif.
1 - 8 of 8 Posts
