I have set of Autometer Ultralites in a pillar pod. The Trans guage is brighter than all the rest and it is driving me nuts. I just changed out all the bulbs from 161's to 194's, and they all got a little brighter, but the trans gauge is still much brighter than the other two. I would like to make the boost and pyro gauges as bright as the trans gauge, not dim the trans gauge to match them. Has anyone had this problem and found a solution yet? I was looking at the LED upgrades. Can I have some opinions on these? Also I have seen an LED dimmer advertised, woul dthis be needed if I changed out to the LED's or is that only for gauges that are built with LED's? Thanks.
