I have a 1997 Ford F350 7.3. The truck has a western bed with a 7 pin rv plug. Just recently I lost power to the black wire, powering the aux. brake battery supply. Can anyone tell me where/if there is a fuse or relay under the hood that supplies power to this wire?
Check fuse #5 a 15 amp fuse and #18 a 30 amp maxi fuse in the under hood fuse box.
#5 is for the Backup Lamps, Daytime Running Lamps (DRL), Trailer Battery Charge Relay
#18 is for the Trailer Battery Charge Relay
Also remember that the key needs to be in the run position for power to the trailer wiring.
It may be similar to these diagrams, but follow the link in the caption to be sure:
