I have to replace my front axle joints on my 04 F250 4x4. I plan on getting SPICER joints but want to make sure I get the right ones. I have been told there are different series, Aa high quality and a low select series that are made in CHINA. Can anyone tell me which are the best ones that are greaseable? Part#? Thanks
If you buy them at a local driveline shop they can help you on that.
The driver side is torn and does need to be replaced. I just wasn’t sure if it was one of those situations where it’s best to do both at the same time since you’d probably have to do the other side not long after.
snaptube vidmate word to pdf
I would change all joints at the same time.
