I have a 93 f350 7.3 4X4 5 speed, the truck was originally SRW, It had a flat bed put on it from the previous owner and a dually adapters put on. My rear diff has gone bad so I'm replacing it with a DRW rearend, My question is if anyone can help can I replace the front wheel spindles to actual dually spindles to take off the adapters so it will be a true dually or do I have to replace the front diff??? Thanks for any help
Its not a spindle thing, its really a factory adapter/spacer, if you find one in a junkyard, just take the rotors with the adapters on them.
Its really kinda a PITA, but its the best way that I've found to do it that's as strong as the factory designed it.
