B/U lights are NFG. Bulbs OK, Truck is 94.5 PSD OBS long box crew cab. Anyone know where the switch is (somewhere in trans?) Trans is 5sp stndrd.
Is there a dedicated fuse for this circuit? Does someone have a detailed and RELEVANT schematic of the electrical for this truck?
Thanks!
From 15A fuse #5 (sometimes labeled "E") in the engine compartment fuse box, Purple wire with orange trace to the switch on the tranny (it's the only wire to the tranny). Black wire with pink trace out to bulbs. Check the grounds from the bulbs and the switch closes in reverse. Cheers!
Thanks loads, Patrick, I'll look tonight after shift.
Jim
