Back with 2001 7.3 shutdown/no start problem. Finally got my AE software and ran a scan. Here is what I found so far. ICP pressure runs up to about 2200 while cranking then falls back to about 240 after cranking stop. ICP volts start at .2 with key on, up to 2.7 while cranking then .5 when cranking stop. Duty cycle start at 14.8 then up to around 40 while cranking. Prior to scanning the CPS, IPR, ICP and pigtail have been replaced. Wires on top of engine look good. Returned a P1280 code which is ICP sensor circuit low. I may have jacked up a crimp on new pigtail which may cause that but not sure that would keep it from starting. KOEO test returned P1293 and P1294 codes which are Injector high side open on both banks. Ideas anyone?
