I think I just lost another injector or two. Lookn for any answers for what makes an injector go bad. I dropped three injectors last winter when it was cold and now the truck is actin the same way (gotta get it to a shop to verify) and its only -20F, wind chill. I use diesel clean in every tank, change the oil every 5000. I keep my banks on 3 and never, and I mean never, tow heavy loads. Just lookn for some suggestions cause I can't do this every winter. Thanks
Low fuel pressure will kill the injectors quickly....... I would check your fuel pressure readings. They should be around 50-55psi and no lower than 45psi...
If they are not, my first suggestion would be to change the fuel filters and recheck. Clogged fuel filters will drop the pressure. Otherwise your pump could be weak....
If your pressure checks out ok, then presuming you have the latest flash, I am at a loss....
Thanks for the info. I like the truck a bunch but this prob is really makn me wanna go back to the v10, which was way weaker that the pstroke, but did n't chew up injectors.
