After flushing the coolant system with restore and restore plus, doing the oil cooler with an OEM one, doing the STC fitting, Sinister full EGR delete, blue spring kit, and a 4 inch MBRP straight pipe, I've noticed there isn't really any "power" and the MPG is horrible about 8 mpg. No codes besides the P0401 (I left the EGR valve plugged in).. Seems like it lacks acceleration. On my way to work I had to hit 2000 rpm before it seemed like it wanted to move. It's not cold out, I'm in south Florida. Any suggestions? Thank you.
Discussion Starter · #2 ·
FICM is fine stays at 49V, I got some archoil AR9100 on the way, put Rotella 15-40W in not sure what dealer or previous owner used before. Stock intake.
I heard when it see's no flow to the EGR valve for whatever reason the truck goes into a "Limp mode" I think you may need to get a tuner and turn that CEL light off.
Hmm.. Good point. There is no DTC or CEL being triggered... I've been mashing it WOT to see if anything changes maybe clean stuff out
You said STC fitting so its a 05+ that should pop a Check engine Light... interesting.... I drove mine for like 6k miles with a CEL no issues.
Yea no CEL, No DTCs... MPG really sucks...
Some sensor readings to check (make sure they are in the normal range and the connector is fully seated):
BARO
EBP
MAP
IAT1 / MAF
Sometimes the EBP sensor tube gets plugged and sometimes the MAP sensor hose gets brittle and gets holes in it.
