1 - 9 of 9 Posts
No matches in the search for Baer Brakes???
Anyone have any opinions on these? Experience's??? It's time for brakes on my truck and I was looking at these for a replacement rotor. I was considering the power slots as well, but I have run Baer's on a few cars back in the day...I'm sure its the same quality, but I would like to hear about them anyway.
I just ordered the cyro'd powerslot rotors with Hawks Superduty pads. These are considered a really good match for our trucks. Another cyro'd rotor is made by ART.
The Baer and Brembo are a complete rotor,caliper and pad system which are a lot of money.
I don't think we have a bad caliper design as long as you keep the slide pins lubed. It is the piece of junk rotors that need replacing.
Stainless Steel Brakes
try a set from SS Brakes:
http://ssbrakes.com/truckstop/products/d...9&year=2000
"Direct bolt-on Force 10 V8 8-piston aluminum calipers and high performance pads. Bolts to stock spindles. Fits in stock wheels."
I ordered a set, and they should be arriving today!
Re: Stainless Steel Brakes
You can get a very good Brembo factory replacement rotor from Tirerack for around 70 bucks a piece.
Where do I look for oversized brake rotors & calipers? I run 19.5 inch rims on my hauler and need some extra braking. Any help would be appreciated. Thanks!!
Soot
Not sure how much you are looking to spend...but you could spend a chunk here.
Discussion Starter · #9 ·
Thanks for the replies fellas...I was going to stick with the stock caliper and just replace the rotor, until I saw DrSpeed's post! Those look pretty nice. Either way I need to decide on a rotor, but I would like to hear about the install and performance of those 8 piston calipers...
1 - 9 of 9 Posts
