I have been researching electronic balance scales for use in measuring ingredients for titration and brewing. The Boreal balances at Edmund Scientific caught my eye. I need some advice as to what range of scale is most useful. I think the lower limit probably does not need to be lower than .1 gram. What should the upper limit be?
500g, 1000g, 2000g?
I will also want to use the scale for measuring moisture content in wood for a dry kiln but that might be a topic for a different forum..
TIA
I just picked up a digital scale at Wal-mart. They have them in the kitchen utensils section. Was about $28. 1 Gram increments and goes up to 999 grams. I do 25 gallon batches and it takes 950 grams of KOH. But the little tray that comes with it won't hold that much so I split it up.
I think its easier to do it in 1 or 2 liters, not a gallon. Check this out :
1 litre oil- new or used
NaOH (lye / caustic soda), at least 6g.
--Used as a drain cleaner and can often be found next to the Drano.
Methanol at least 250ml.
--HEET® Gas- Line Antifreeze in the yellow bottle is methanol and readly available in most auto supply stores in the USA.
Hope this helps,
J.R.
Hope this helps,
J.R.
I saw this when I made my test batch. I just hate dealing with metrics. I figured someone would have converted it over to standard form for us mentally challenged persons. /ubbthreads/images/graemlins/biggrin.gif Thanks.
1 litre = .2642 gallons
1 gallon = 3.7843 liters
