21 - 25 of 25 Posts
Hammer, does Zane's truck already have huge injectors?
edit - that's a silly question... it must! /ubbthreads/images/graemlins/cool.gif
Banned
As for damaging the engine... well, there's a truck belonging to Wide Open Performance with compound turbos, makes up to around 100 psi from what I understand... on the STOCK PCM: no programming of any kind... yet. /ubbthreads/images/graemlins/cool.gif
Bet that's not on stock headbolts and gaskets. /ubbthreads/images/graemlins/wink.gif
Woopsie... yeah, there's those small details that should be mentioned. /ubbthreads/images/graemlins/biggrin.gif
But with the Big Head, we're generally talking 25-32 psi.... not 100. /ubbthreads/images/graemlins/smirk.gif /ubbthreads/images/graemlins/blush.gif
Some report good luck adjusting the OE waste gate tighter 3 to 6 turns. Some report breaking the rod while trying.
For a stock truck IMO put your $$$ elsewhere.
You don't need programming if you have huge injectors that spray a ton of fuel at stock pulsewidth.
Priceless...Thanks....R
My waste gate is blowing open at 22 psi. if I tighten up the rod some will this help solve my problem.
21 - 25 of 25 Posts
