Re: Banks six gun installation
I thought i would add some troubleshooting detail.
If i wait to plug the sixgun in after the engine is running I recieve no error codes and everythiing seems to be working fine.
For those not familiar with the banks install, power is supplied to the unit via piggy backing on a fuse. Its not bad but you cannot have power to the fuse you are going to use untill the ignition key is turned. Other wise the unit is always on. Following banks instructions has me plugging into the wrong fuse. Banks documentation does not say what size fuse to use they only say to use fuse 22. My guess is this would be acurate for a PU but not for the Econoline.
Thanks again.....
