My '00 F350 has a battery drain since back from repair. Someone tried to steal my truck and broke the ignition switch which was repaired at the local dealer. Since then I had to jump it once. Was able to start it after sitting once and now cant even jump it. (at least with a car)
It does really weird things when you try to start from the door marker lights and dome light flashing with a click as if the directional is on. (It did stop this) Other times the windshield wipers go on when I turn on the switch. My batteries seem marginal. One will not take a full charge the other does. (charging with the battery disconnected with a 10 amp charger) When I reattach the battery the voltage drops right a way.
The charge has a 50 amp emergency jump start setting. I tried it and it the truck still would not start.
Could this be a short they caused when they were working in the column? They had to get one from salvage to get all the clips they needed. I am not sure how much they used.
Any ideas before I call them screaming tomorrow?
Kevin
Kevin
