1 - 10 of 10 Posts
Ok my battery light came on and my dash lights and gauges shut down. A/c came on also. Truck ran fine and I just checked both batteries and alternator. Everything seems good. Any ideas why this is happening?
When you say you checked your batteries and alternator, what did you do to check them? I'm guessing by your screenname you have a 2011? Are these the original batteries? If so, they are on their way out. Give us more info.
Ok yeah so it's 2011 f350 6.7 105000 miles. Checked voltage while truck was off. 12 volts. When truck was running it was 14.5 Both batteries. I just took it out for another ride and the battery light is still on and I noticed the idol is a little higher than usual Like 800 or so. I did not lose gauges in this last test ride. I want to say both batteries are original.
The batteries need to be isolated from each other to the tested. One of the batteries might be bad.
If it's the original batteries, they are going out on you. Mine went a few months back. When you get new ones, be sure and get both. Don't get just one thinking it'll be okay.
Ok so I isolated each battery and the readings were same. I tried to start and run truck on 1 battery at a time and one would not start truck. I swapped the battery with my van battery and still have the same battery light on with high idle. Dealer is going to rape me for this repair I'm sure.
Keep us updated and let us know how it turns out.
One of my 2011 batteries died exactly 5 years after build date. I replaced both. Ford had the best deal. I upgraded to the 850 amp hour.
That's exactly what I did. I priced batteries all around, and ended up getting them from the dealer. Now I put them in myself, which was interesting. My radio was dead afterwards. I thought I would have to take it to the dealer anyway. But I disconnected them both, reconnected and the radio came back to life. A "phew" moment for sure.
1 - 10 of 10 Posts
