I have done a lot of research and searching and have come to the conclusion that I need to ask for help. I added LED turn signal bulbs along with resistors to my truck about two years ago to my 2012 F250 6.7. They work perfectly as long as I have my parking lights on(no hyper flash). If I forget to turn on my parking lights and hit my blinker, I get hyper flash. I immediately turn on the parking lights and the hyper flash goes away. After a month or two of sometimes forgetting to turn on my parking lights, the BCM stored up enough faults to set a DTC code and disable the left or right blinker circuit. After some research, I figured out that a simple DTC erase with a handheld programmer allowed everything to return back to normal. A year later after forgetting to turn on the parking lights numerous times again, the BCM disabled the left or right blinker circuit(don't recall which one). I used the handheld programmer again to erase the DTC codes and all was back to normal again. Fast forward to two weeks ago and the hyper flash started on the right side, but no amount of handheld programmer erasing fixes the problem. There is no voltage on the front right blinker wire. The right mirror light works, the rear right blinker works and the whole left side blinker set is all working fine. I have contacted the company that I bought these bulbs from and they assure me that there is a fix that I will be looking into. For now, I will remove the LED bulbs and switch back to stock.
Now, I have done two weeks of internet searching and I just need some clarification from someone that knows. Here are the options that have been presented to me from the internet, my local Ford Dealer and a local authorized Ford repair shop...
1. Buy a new BCM from Ford. When it arrives, I can have the authorized shop or Ford Dealer with IDS software download my "As Built" data and install it. But, they are on backorder with no estimated ship date.
2. My local shop says he has a used BCM that he can install and program using the IDS software.
3. I found a company called Module Experts that claims that they can rebuild my BCM. They specialize I told him my issues and he says they can fix it in three days. I was under the impression that these were not repairable, but they seem to believe they know how. This is a very cost effective option.
So, I would like some feedback from the brains of the group. I do not know enough to speak on the subject. I have my fingers crossed that the BCM rebuild company is a viable option. It would save me a lot of money. But, I'm not much for gambling. I would hate to send it to them and lose a week of time for nothing.
Thanks in advance...
