1 - 20 of 51 Posts
I tow a 33 ft 5th wheel thats about 14,000lbs. I tow both on road and on beaches . I've had Bridgestone Dueler AT Revos, I liked them but they only lasted 35K miles. Switched over to the Nitto Terra Grappler also 35K miles. (liked them but not as much as the Bridgestones) They both wore evenly but not happy on the tread life. Always kept tire pressure up to snuff and rotated properly.
Any suggestions on a good AT towing tire that will get good tread life?
Michelin's maybe?
thanks
i ran the revos and had the same issues. then switched to han**** atms and same issue. now I have gone with michelin highway ribbed. (fronts only as the ATMS still have another 40k plus left on rears.) expensive tires but from what I have read in tirerack.com alot of people are getting 80k plus out of them. I too tow alot and alot of weight. about 20k. I also added airbags to help keep the truck level and front tires down.
Yours are lasting longer than BFGoodrich AllTerrain or Cooper Discoverer did on mine. I switched to Michelin XPS Rib and they are lasting a lot longer. I have over 50,000 miles on mine now, and the worst worn has 8/32nds tread left, with the others having 11 and 12/32nds tread left.
Not cheap. $271.48 at Sam's Club. Over $300 at my local Michelin dealer.
Sam's Club-LT235/85R16E 120/116Q Michelin® XPS® RIB
The XPS is available in two tread patterns, Rib and Traction. The traction tread costs about $12 more per tire, and they won't last as long as the Ribs. I wore out one set of Tractions, but since I don't really need the agressive tread I'm running the Ribs this set.
My second choice would be the Michelin LTX M/S2 - only $203.88 at Sam's Club.
Sam's Club-LT235/85R16E Michelin® LTX® M/S2
But even cheaper at our sponsor Discount Tire. $175.
http://www.discounttire.com/dtcs/fi...&fcsr=&fcs=false&fcb=&ct=null&pager.offset=10
Now if we could just talk Discount Tire into selling the XPS Rib. :)
I don't have any experience with the new LTX M/S2, but Michelin rates them as higher tread mileage than the XPS Rib. Plus the biggest size the XPS comes in is LT235/85R16 while the LTX M/S2 also comes in LT265/75R16 and LT285/75R16.
Are we talking total treadlife or miles/dollar?
Tire Products By Vehicle - Discount Tire
I ordered mine from discount tire so just ask them and they can get them. usually with in a couple of days. They also price match from the net. i got my price match from discountwarehouse for $207 per tire and discount tire matched there price. i did order the michelin xps ribbed
Treadlife in miles. You cannot compute miles per dollar until you know (or estimate) treadlife.
OP, I would say your tire life was exceptional for the conditions.
I certianly wouldn't be complaining about that.
Highway ribs are an option, but I myself wouldn't run them unless I was towing full time.
I had the Nitto DuraGrapplers on my '08 SRW, and loved them. In fact, whenever the tires on the new dually wear out, I plan to replace them with Duras.
They are more of a hiway tread than AT, but have enough lug to do OK in mild mud and sand. They are extreemly quiet and smooth, and tow great!!
At Discount Tire, they are around $150 for a 235/85-16. Not bad for a E rated tire.
Disc Tire
Mark
Having gone through a lot of tires in the last 10 years towing with these SuperDuties. I think any tire that gets more than 30,000 miles tread life
is doing great.
They are heavy trucks and when you are towing a lot, it wears the tires out fast.
This past year I decided to try the Goodyear Silent Armor tires. They are supposedly built for this heavier trucks. They have a pro rated 50k tread warranty. About the only AT tire that offers any kind of tread warranty. Tires did great in winter snow. They were not noisy. I was pretty impressed with them until this summer when it got hot and they started bulging on the sidewall. Tire dealer said I was overloading them. I replied I'm pulling the same trailers that I have for the past 10 years and none of the previous Conti, Toyo and other brands of tires have ever bulged. I replaced two tires at 16,000 miles in July. I just don't think they held up to the weight and the 100* heat of July.
As you can see, there is no obvious external damage that caused the bulge.
That looks like a defect. I hope they replaced it under warranty.
BTW, your replacement list for your 06 is very scary Painted Horse.
I guess I should edit my sig, The turbo went out at 108,000 and that was the final straw that pushed into buying the new 2011 truck. I don't mind changing the oil or fuel filters, But I really don't enjoy replacing serpentine belts or turbos.
I don't think the 6.0 was a bad engine. I just work the trucks hard. Between my horse trailer, Skid loader, Mini excavator, and dump trailer. My truck was towing something more than it ever was driven empty.
I had two tires that looked exactly the same during July. About 3 weeks apart. They did replace them but after they charge you the Pro-Rated mileage fee of about a $150. You kinda wonder if you came out ahead. I was pretty impressed with the Goodyears up until these failures.
You did not say if your truck was SRW or DRW. SRW trucks usually don't get good tire life when towing, just too close on the weights. Using my truck (sig), I have consistantly gotten over 100,000 miles on rears and 85-90,000 on fronts. That has been with every make of tire I have put on it.
I used to pull camper and other trailers for a transport company and have 398,000+ miles on my truck. Trailers have ranged from an empty boat trailer to a 16k, multi-slide
5'er. Granted, most all those miles have been highway and are not as taxing as city driving.
Tire presures are the most important thing for good tread life. I have found running 60psi cold in the rears and 70psi cold in the fronts to give me the best tread wear. The tires I have had the best luck with are BF Goodrich Commercial TA's (from Discount Tire). Last set of rears were replaced at 116,000 miles with 4/32's left. Current front tires are at 58,000+ miles with 8/32's left.
Hope this helps and good luck.
Discussion Starter · #13 ·
I have SRW. I I'm leaning toward the Michelin LTX A/T 2"s. Costco has a sale good until 10/13 for $70 off a set of 4 Michelin tires. So that's about $210 per tire plus tax. Plus Costco will do free tire rotation,balancing and flat fixes. which here in NY will save me $$$ over a few years. The tire Manager says I should get at least 60,000 from these tires if I treat them right (which I always do)
appreciate all of the input.
If life and durability are your biggest factors then the Michelin XPS ribs or XPS traction are the winners. I do think they are a bit harsher due to ALL steel carcass and tread plies.
I have been through a small fortune in trailer tires on living quarter horse trailers and the XPS ribs are the ONLY tire that holds up to it that you can find readily available (they are some commercial tires for low boy trailers hauling heavy equipment that re high load rated and durable but cost twice what the XPS Ribs do).
I have had the G rated Goodyear purpose built trailer tires in three different models all fail for no reason and I was blaming it on road debris but when I switched to XPS ribs on trailers I have had no blowouts and the trailers have been dragged many more tens of thousands of miles over the same roads since switching. These tires have been great on trucks too.
How did those BF Goodrich Commercial TA's do in the winter snow and ice?
Old thread but FYI, my sister's truck had BFG ATs and the front left blew out while towing a 5th wheel causing the entire rig to slide sideways across the interstate into oncoming traffic lanes. No fatalities but Michelin declined to accept any liability for a defective tire and they were screwed big time financially.
· Super Moderator
I don't think that you will ever find a tire manufacture that will admit liability for a tire blowing out and causing damage or a wreck. There are way too many variables in the equation for them to do so.
I had a brand new set of nito grapplers with less than a 1,000 miles on them let go last year. The right rear blew while I was pulling our 35' triple slide fifth wheel weighing over 16,000lbs while going down stone Mountain. It was a hell of a ride I got a hold of my triler brek controller and turned the gain all the way up and keep us half ass straight getting it to a stop in the right side ditch. I flat spotted all 4 trailer tires and broke all the cordes in the drivers side rear tire. Needless to say nito will never be on my truck again. The tires were instaled the day before we left so I got two days out of them. But I am glad this thread came up because I forgot my buddy who owns the tire owes me a new set of tires. Since we had to buy new ones on the road.
· Super Moderator
The brown stuff happens and it usually happens at the wrong time.
Just this last February a friend and I were headed to Tucson to so some javelina hunting and had 2 4 wheelers up on the bed of his truck when he told me that he thought that he had a flat tire. We got out and inspected all 4 of the tires and they looked good and up to pressure. Less than 5 miles down the road the drivers side front let go on a 2 lane road and the rodeo was on.
The tires had been sold and installed by Discount Tire and when we went into the dealer in Tucson and told them what had happened along with one of the tires blowing out on my friend as he was pulling his 5th wheel the gave him 4 brand new tires. The one rim that was now half a rim couldn't be reused so they sold him a rim at their price. But no where did they admit that it was their tires fault but they took real good care of him and he was out the door with 4 brand new tires and a rim for only a couple hundred bucks which the rim cost.
Just remember Fords go around with tires and the Explorer I believe. They never did admit that it was the tires fault or the manufactures fault when those tires were blowing and causing roll overs. I believe that the final outcome was that the tires were being ran at below recommended air pressure and the fault was on the owners. Now we have TPMS on all the vehicles because of this.
Reactions: ArcticDriver
Well....
Didn't Firestone?
That whole ordeal was before my driving time. Lol so I don't recall a whole lot about it
Sent from my SM-G892A using Tapatalk
1 - 20 of 51 Posts
