The easy answer is to buy an F-350 instead of a 250, but since I didn't...
What is the best way (money is a concern) to make this nose up look go away-
To be fair there are some totes in the bed, but then again there is a fully loaded cooler on the back of the trailer that should be helping ease tounge weight as well.
For Comparison, here is my last ruck with the same load, sitting flat, no aftermarket dohickeys required-
What I'm considering is Overload springs vs. Air bags vs. blocks.
Blocks- If I could block the rear up another 1/2" or so it would have a nice mild rake to it unloaded then flatten out when loaded. I was in traffic next to a 2011 short box CC F-350 the other day & LOVED the way it looked compared to mine.
Airbags- If I go airbag, which brand looks & works best? Can you just add air when needed or is it best to have the onboard compressor & gauges.
Springs- Overload springs that only take effect when loaded- I've heard they last longer than bags, but are unadjustable. Are they a more heavier duty cost effective option?
Thx for the help.
I knew the ride was smoother in the F-250, now I know how they made it happen. There is no magic to the smoothness.
Thx for the help.
