I have a 2002 F350 Crew Cab 4x4 7.3L I am new to the diesel world my first one. i was wondering if anyone could give me an idea on where to start to get better MPG's as far as i can tell it is totally stock
4x4: Big killer of MPG and it forecloses some effective mods. Figure that half-ton of machinery costs you at least 2 MPG vs a 4x2 truck.
Automatic transmission: Another big MPG-killer. It is good for 2 MPG
Dually: It will cost you 1 MPG over a SRW
Crew Cab: It will cost you 0.75 MPG vs a regular cab
Club Cab: It will cost you 0.5 MPG vs a regular cab
Big tires: Anything over 235-85 or 265-75 will hurt. Figure 285s will cost you 1 MPG 305s will cost yet another 1 MPG
Lift: It will cost you 2 MPG
Gearing: Very strong effect on MPG
3.55s will get 1 MPG better than 3.73s (all else equal)
3.73s will get 1 MPG better than 4.10s
My 3.08s (not widely available) improved my economy by 3 MPG over the stock 3.73s
An overdrive (US Gear or Gear Vendor) will improve most trucks by 2-3 MPG
Be very careful about re-gearing if you have an automatic
The 6.4 is somewhat less efficient due to EGR and the filter thingy but I would expect a RC 4x2 six-speed SRW with stock tires and the stock 3.73 gears to get 19-20 MPG if driven normally.
All the stuff above adds up.
A CC 4x4 automatic dually with 305s and a lift and 4.10 gears should expect about 9-10 MPG.
To add insult to injury, the higher MPG truck will probably set you back $10-12,000 less up front. Even with my exotic drivetrain and aero mods, my truck may be one of the ten lowest-cost trucks in The Diesel Stop community.
All these numbers square with my experience and what I have found out talking to literally hundreds of guys plus design engineers.
Its your money. You know what you want/need. Get what you will but those numbers outline the unmodded MPG you can expect. The specification sheet is a powerful tool.
