The only other method of puting front type calipers on the rear would be to use these: fordmann.com | 4x4van: Axles: Future Rear Disc Conversion (project not finished yet).
The stock rotor for those brackets is 12.5" diameter and 1-1/4" thick. You have the option of many different 4x4 rotors (Ford, GM, Dodge) depending on the "hat" depth you like.what rotors would be usd with this conversion ??
Could you just put the OBS hubs on the SD rear axle w/ van rotors?I have the chevy setup but will soon be moving to super duty rear brakes. Near as I can tell once I get the calipers, pad brackets and main brackets off the SD I can cut the flange off the 10.25 and fab a matching flange for the SD parts and weld it on. Using the Van rotors you will have a fully functional (as much as they function...) parking brake and more braking power then the chevy setup. Just have to change the rear cables for the parking brake.
No. The OBS hubs are wider than the SD.Could you just put the OBS hubs on the SD rear axle w/ van rotors?
