Ok, here goes the dumb question of the day. But, I since I don't know I have to ask. My neighbor has a Big Cam Cummins in an older C/O and it started intermixing oil and water. He had another mechanic friend briefly look at it and advised him on what to do, because he did not have the time to fix it. He said pull the manifolds and see which cylinder is bad, pull the pan, the bad cylinders piston and the cylinder head of the bad cylinder. Then replace all bad gaskets and reassemble. I understand the head removal, but why the piston? I'll probably be doing the work on this engine and don't want to take things apart that don't need to. Thank you in advance for all input.
