I've noticed a lot of fuel-related posts lately so I thought I would throw together some part numbers for everyone.
This post is best viewed at a very high resolution (everything is really tiny and hard to read). :p
These are all from my 1997 Ford Light Truck Master Parts Catalog so please verify before purchasing anything.
All listings follow:
Model/Restrictions | Part No. | Description | Qty.
9002 TANK ASY. (FUEL)
F350--133" WB 4x4, w/E4OD-Diesel | FOTZ-9002-H | 23 gal.-Midship (Plastic) | 1
F350, F(Super Duty)--137", 161", 185" WB | FOTZ-9002-C | 19 gal.-Aft Axle (Plastic) | 1
F59(stripped Chassis)--7.3L | E9TZ-9002-A | 40 gal. | 1
F350--117", 133", 139", 155", 168" WB | F6TZ-9002-A | 18 gal.-Aft Axle (Steel) | 1
F350, F(Super Duty)--133" (Exc. 4x4 w/E4OD), 137", 155", 161", 168" & 185" WB | F6TZ-9002-N | 19 gal.-Midship (Steel) | 1
F250--117", 133", 139", 155", 168" WB; O/8500 GVW | F6TZ-9002-A | 18 gal.-Aft Axle (Steel) | 1
F250--133" (Exc. 4x4, w/E4OD), 137:, 155", 161", 168" & 185 WB; O/8500 GVW | F6TZ-9002-N | 19 gal.-Midship (Steel) | 1
9K002 SHIELD ASY. (FUEL TANK)
F350, F(Super Duty)--Crew Cab | EOTZ-9K002-B | Use with midship fuel tank - not used when skid plate is installed - steel | 1
F350--Crew Cab | N605908-S40 | (AB-121-C) - bolt (shield to frame) hex. head - M8 x 35mm | 3
9K014 SHIELD ASY. (FUEL TANK)
F350--(Chassis Cab) - 137" W.B. | E5TZ-9K014-F | Use w/midship tank | 1
F350--133" 4/w/d w/E4OD, 117", 139" W/B | FOTZ-9K014-J | Use w/midship tank | 1
F350--133", 168" W/B | E5TZ-9K014-C | Use w/midship tank | 1
F350--155" W/B 4/W/D | E5TZ-9K014-C | Use w/midship tank | 1
F350, F(Super Duty)--2/W/D 133", 137", 155", 161" W/B | E5TZ-9K014-D | Use w/midship tank - 2 piece driveline | 1
F(Super Duty)--185" W/B | E5TZ-9K014-F | Use w/midship tank (plastic end shield) | 1
F(Super Duty)--185" W/B | F2TZ-9K014-A | Use w/midship tank (steel top shield) | 1
F350-137", 161" W/B - diesel w/ambulance prep pkg. "FROM 10/94" | E8TZ-9K014-C | Use w/midship tank O/8500 GVW | 1
F250--(Chassis Cab) - 137" W.B.; O/8500 GVW | E5TZ-9K014-F | Use w/midship tank | 1
F250--133", 168" W/B; O/8500 GVW | E5TZ-9K014-C | Use w/midship tank | 1
F250--133", 4x4, w/E4OD, 117", 139" WB; O/8500 GVW | FOTZ-9K014-J | 1
F250--137", 161" WB - diesel w/ambulance prep pkg.; O/8500 GVW "FROM 10/94" | E8TZ-9K014-C | Use w/midship tank | 1
F250--155" WB, 4x4; O/8500 GVW | E5TZ-9K014-C | Use w/midship tank | 1
F250--4x2, 133", 137", 155", 161" WB; O/8500 GVW | E5TZ-9K014-D | Use w/midship tank - 2 piece driveline | 1
9K024 PLUG ASY. (SUPPLY RAIL)
F350, F(Super Duty)--DI Turbo diesel | 8 Cyl. 7.3 | F4TZ-9K024-A | Supply rail-R.H. Cyl. Hd....Includes o-ring F4TZ-9N693-A | 1
9030 CAP ASY. (FUEL TANK FILLER)
F350, F(Super Duty), F53(Stripped Chassis), F59(Stripped Chassis) "FROM 6/22/93" | F4TZ-9030-C *FC-920 | 1/2
9A032 SHIELD (FUEL TANK HEAT)
F350--133" W/B 4/W/D w/E4OD-diesel | FOTZ-9A032-H | 1
F250--133" WB, 4x4, w/E4OD-diesel; O/8500 GVW | FOTZ-9A032-H | 1
F350--(Regular Cab) | 39909-S7 | (U-269-D) - screw (shield to frame crossmember) - hex. washer head - self tapping - 5/16" - 18 x 3/4" | 3
9034 PIPE ASY. (FUEL TANK FILLER)
F350, F(Super Duty)--Chassis Cab - 133" W/B - diesel "FROM 2/94" | F4TZ-9034-H | Use w/aft axle fuel tank (steel) - NOTE: Vehicles built before 2/7/94 must also order F4TZ-9B593-H (valve assy) | 1
F350, F(Super Duty)--Chassis Cab - 133", 161", 185" W/B - diesel "FROM 2/94" | F4TZ-9034-J | Use w/aft axle fuel tank (plastic) - NOTE: Vehicles built before 2/7/94 must also order F4TZ-9B593-G (valve assy) | 1
F250--aft axle tank - SRW (99); O/8500 GVW | FOTZ-9034-L | (Leaded or diesel fuel) | 1
F250--aft axle tank DRW (99); O/8500 GVW | FOTZ-9034-K | (Leaded or diesel fuel) | 1
F250--midship tank - DRW (99); O/8500 GVW | FOTZ-9034-H | 39" long (leaded or diesel fuel) | 1
F250--midship tank - SRW (99); O/8500 GVW | FOTZ-9034-G | 33" long (leaded or diesel fuel) | 1
F250--4x2 (83); O/8500 GVW | 304646-S8 | (B-42-A) - bolt (fuel tank filler pipe to body side panel) - hex. head - 1/4" - 20 x 3/4" | 3
F250--2x2 (83); O/8500 GVW | 375474-S8 | (MM-120-B) - nut (pipe assy. to body( - rivet type - 3/8" - 16 - used with auxiliary under-cab fuel tank | 2
F250--O/8500 GVW | 51764-S8 | (U-366) - screw (fuel tank filler pipe to body) - pan head - cross recessed - tapping - No. 8 - 32 x 1/2" | 3
9K037 BRACKET (FUEL TANK SHIELD)
F350, F(Super Duty)--137" W/B - diesel w/ambulance prep. pkg. | E8TZ-9K037-C | 1
F350, F(Super Duty)--161" W/B - diesel w/ambulance prep. pkg. | E8TZ-9K037-D | 1
F250--137" WB, O/8500 GVW, diesel w/ambulance prep. pkg. | E8TZ-9K037-C | 1
F250--161" WB, O/8500 GVW, diesel w/ambulance prep. pkg. | E8TZ-9K037-D | 1
9038 PIPE (FUEL TANK FILLER LOWER)
F350--Chassis Cab - all | EOTZ-9038-A | Use with midship or aft axle fuel tank (outer hose) | 1/2
F350--Chassis Cab - all | EOTZ-9038-A | Use with midship or aft axle fuel tank (inner hose) | 1/2
9C038 BRACKET ASY. (FUEL TANK SKID PLAT FRONT)
F350 | FOTZ-9C038-A | 1
F250--O/8500 GVW | FOTZ-9C038-A | 1
9040 BRACKET (FUEL TANK FILLER PIPE)
F350 | EOTZ-9040-B | Use with midship or aft axle fuel tank | 1/2
F250--O/8500 GVW | EOTZ-9040-B | Use with midship or aft axle fuel tank | 1/2
9N045 INSERT (FUEL FILTER SEDIMENT BOWL)
F350, F(Super Duty), F59(Stripped Chassis)--diesel-exc DI Turbo | E8TZ-9N045-A | 1
F250--diesel-exc DI Turbo; O/8500 GVW | E8TZ-9N045-A | 1
9046 BRACKET (FUEL TANK SUPPORT)
F350(81) | E3TZ-9046-A | 1
F250(81)--O/8500 GVW | E3TZ-9046-A | 1
9047 HOSE (FUEL TANK TO FILLER PIPE)
F350 | C9AZ-8287-B *YF-234 | Clamp assy. (filler hose) - adjustable - 2 1/16" I.D. to 3" I.D. | 2
F350, F(Super Duty)--(Chassis Cab) - 133" W/B "FROM 2/94" | F4TZ-9047-G | Use w/steel aft axle tank | 1
F350, F(Super Duty)--(Chassis Cab) - 133", 137", 161" W/B "FROM 2/94" | F4TZ-9047-F | Use w/midship tank | 1
F350, F(Super Duty)--(Chassis Cab) - 137", 161" W/B "FROM 2/94" | F4TZ-9047-H | Use w/plastic aft axle tank | 1
F250--O/8500 GVW | C9AZ-8287-B *YF-234 | Clamp assy. (filler hose) - adjustable - 2 1/16" I.D. to 3" I.D. | 2
9049 TUBE (FUEL TANK VENT)
F350(99)--exc. dual rear wheels | E4TZ-9049-A | Use w/aft axle fuel tank - nylon tubing - approx. 19" long | 1
F350(99)--exc. dual rear wheels | EOTZ-9049-H | Use with midship fuel tank - nylon tubing 5/8" I.D. x 11/16" O.D. x 25 1/16" long | 1
F250(99)--exc. dual rear wheels; O/8500 GVW | E4TZ-9049-A | Use w/aft axle fuel tank - nylon tubing - approx. 19" long | 1
F250(99)--exc. dual rear wheels; O/8500 GVW | EOTZ-9049-H | Use with midship fuel tank - nylon tubing 5/8" I.D. x 11/16" O.D. x 25 1/16" long | 1
9A050 SWITCH ASY. (FUEL TANK SELECTOR)
F350, F(Super Duty)--diesel | F2TZ-9A050-B | graphics-button-'fuel-front-rear' | 1
F250--diesel; O/8500 GVW | F2TZ-9A050-B | graphics-button-'fuel-front-rear' | 1
F350, F(Super Duty) | 356098-S2 | (MM-122-A) - switch to instrument panel nut - 1/2" - 28 | 1
F350, F(Super Duty) | 376389-S101 | (UU-82-D) - screw (switch to instrument panel heater opening control cover retainer) - pan head - cross recessed - tapping - No. 8 - 18 x 3/4" | 1
F250--O/8500 GVW | 356098-S2 | (MM-122-A) - switch to instrument panel nut - 1/2" - 28 | 1
F250--O/8500 GVW | 376389-S101 | (UU-82-D) - screw (switch to instrument panel heater opening control cover retainer) - pan head - cross recessed - tapping - No. 8 - 18 x 3/4" | 1
9053 SUPPORT (FUEL TANK)
F150, F350--117", 133", 168" W/B - w/o Skid Plate | F1TZ-9053-A | 2
F150, F350--Super Cab-w/o Skid Plate | F1TZ-9053-A | 2
F350 | D8TZ-9053-B | Used as No. 5 frame cross member | 1
F250--(Regular Cab) - 4x4, - 133" W/B; O/8500 GVW | D8TZ-9053-B | Used as No. 5 frame cross member | 1
F250--(Super Cab) - 4x2, 138" WB; O/8500 GVW | D8TZ-9053-B | Used as No. 5 frame cross member | 1
F250--(Super Cab) - 4x4, 155" WB; O/8500 GVW | D8TZ-9053-B | Used as No. 5 frame cross member | 1
F250--117", 133", 168" WB; O/8500 GVW; w/o Skid Plate | F1TZ-9053-A | 2
F250--Super Cab, w/o Skid Plate; O/8500 GVW | F1TZ-9053-A | 2
F350--4/W/D | 382802-S2 | (MM-173-JB) - nut - hex. lock - 3/8" - 16 | AR
F350--4/W/D | 44727-S8 | (X-24) - washer - flat - 3/8" | AR
F350--4/W/D | 383107-S36 | (BB-545-EY) - bolt (support to frame crossmember) - hex washer head - 3/8" - 16 x 1" | 4
F350 | 382401-S | (MM-284-E) - nut and retainer assy. - locking - 7/16" - 14 | AR
F350 | 351428-S7 | (XX-166) - washer (support to frame) - flat - 7/16" | AR
F250--4x2; O/8500 GVW | 56340-S2 | (B-323) - bolt (support assy. to frame cross member) - hex. washer head - (UBS) - 3/8" - 16 x 1 5/32" - use with aft axle tank | 4
F250--4x4; O/8500 GVW | 383107-S36 | (BB-545-EY) - bolt (support to frame crossmember) - hex washer head - 3/8" - 16 x 1" | 4
F250--4x4; O/8500 GVW | 382802-S2 | (MM-173-JB) - nut - hex. lock - 3/8" - 16 | AR
F250--4x4; O/8500 GVW | 44727-S8 | (X-24) - washer - flat - 3/8" | AR
F250--O/8500 GVW | 382401-S | (MM-284-E) - nut and retainer assy. - locking - 7/16" - 14 | AR
F250--O/8500 GVW | 351428-S7 | (XX-166) - washer (support to frame) - flat - 7/16" | AR
9054 STRAP ASY. (FUEL TANK)
F350, F(Super Duty)--133", 155", 161", 168", 185" WB | E8TZ-9054-A | Front - attaching hole dia. 25/64" - use w/midship tank | 1
F350--133", 137", 155", 161", 168" W/B | E8TZ-9054-E | Rear - attaching hole dia. 25/64" - use w/midship tank | 1
F(Super Duty)--133", 137", 155", 161", 168" WB | E8TZ-9054-E | Rear - attaching hole dia. 25/64" - use w/midship tank | 1
F350, F(Super Duty)--137" WB | E8TZ-9054-C | Front - attaching hole dia. 25/64" - use w/midship tank | 1
F350(81), F(Super Duty)(81)--137", 161" WB | D6TZ-9054-AA | Use w/midship tank mounted O/S of frame | 2
F350--4x4, 133" WB diesel w/E4OD | E9TZ-9054-C | Front-w/skid plate | 1
F350--4x4, 133" WB diesel w/E4OD | E9TZ-9054-D | Rear w/skid plate | 1
F250--117", 139" WB; O/8500 GVW | E8TZ-9054-B | Front - attaching hole dia. 25/64" - use w/midship tank | 1
F250--133", 155", 161", 168", 185" wB; O/8500 GVW | E8TZ-9054-A | Front - attaching hole dia. 25/64" - use w/midship tank | 1
F250--133", 137", 155", 161", 168" WB; O/8500 GVW | E8TZ-9054-E | Rear - attaching hole dia. 25/64" - use w/midship tank | 1
F250--4x4, 133" WB diesel w/E4OD; O/8500 GVW | E9TZ-9054-C | Front-w/skid plate | 1
F250--4x4, 133" WB diesel x/E4OD; O/8500 GVW | E9TZ-9054-D | Rear w/skid plate | 1
F350 | 20349-S8 | (B-170) - bolt (strap to support) - 3/8" - 24 x 3/4" - not used with 30 gallon tank | 4
F350 | 382286-S | (BB-429-AC) - bolt (strap to bracket) - hex. head - 3/8" - 16 x 2 5/8" - use with midship inside frame | 1
F350 | 34370-S8 | (M-99)-nut-lock-3/8"x24" | AR
F350 | 382802-S2 | (MM-173-JB) - locknut (bumper to side rail) - 3/8" - 16 | AR
F350 | 383406-S100 | (MM-173-MY) - nut - hex. locking- 3/8" - 16 | AR
F350 | 72035-S7 | (N-51) - pin - cotter - 1/8" x 1" - (8/94) | AR
F350 | 44727-S8 | (X-24) - washer - flat - 3/8" | AR
F250--O/8500 GVW | 20349-S8 | (B-170) - bolt (strap to support) - 3/8" - 24 x 3/4" - not used with 30 gallon tank | 4
F250--O/8500 GVW | 382286-S | (BB-429-AC) - bolt (strap to bracket) - hex. head - 3/8" - 16 x 2 5/8" - use with midship inside frame | 1
F250--O/8500 GVW | 34370-S8 | (M-99)-nut-lock-3/8"x24" | AR
F250--O/8500 GVW | 382802-S2 | (MM-173-JB) - locknut (bumper to side rail) - 3/8" - 16 | AR
F250--O/8500 GVW | 383406-S100 | (MM-173-MY) - nut - hex. locking- 3/8" - 16 | AR
F250--O/8500 GVW | 72035-S7 | (N-51) - pin - cotter - 1/8" x 1" - (8/94) | AR
F250--O/8500 GVW | 44727-S8 | (X-24) - washer - flat - 3/8" | AR
9061 SUPPORT (FUEL TANK)
F350--4/W/D - A/T 133" W/B | FOTZ-9061-A | 1
F250--4x4, A/T, 133" WB, O/8500 GVW | FOTZ-9061-A | 1
9K061 VALVE ASY. (FUEL FILTER TO TANK)
F350, F(Super Duty), F59(Stripped Chassis), F250--Diesel-exc DI Turbo | F2TZ-9K061-A | use on Engine Serial# 943929 & above | 1
9C064 O RING (FUEL FILTER WATER SENSOR PROBE)
F350, F(Super Duty), F59(Stripped Chassis)--7.3L DI Turbo | F4TZ-9C064-A | Included with water sensor probe (9S281) and oil pressure switch (F6TZ-9278-AA). | 1
F250--7.3L DI Turbo, O/8500 GVW | F4TZ-9C064-A | Included with water sensor probe (9S281) and oil pressure switch (F6TZ-9278-AA). | 1
9065 BRACKET (FUEL TANK)
F350, F(Super Duty)--161", 185" w/b | E8TZ-9065-A | Use w/midship tank | 1
F250--161", 185" WB | E8TZ-9065-A | Use w/midship tank | 1
9092 STRAP ASY. (FUEL TANK SUPPORT)
F350--(Crew Cab) | F6TZ-9092-AB | Use with aft axle tank | 2
F350--(Regular Cab) | F6TZ-9092-AB | Use with aft axle tank | 2
F350--(Super Cab) | F6TZ-9092-AB | Use with aft axle tank | 2
9A095 LABEL (DISEL FUEL ONLY)
F350, F59(Stripped Chassis) | E43Z-9A095-B | English and French wording | 1
F350 | E43Z-9A095-A | English wording | 1
9A147 PLATE (FUEL TANK SKID)
F350--4/W/D - 133" W/B | EOTZ-9A147-G | Use w/midship tank - nose shield | 1
F350--4/W/D-116", 133", 139", 155", 168" w/b w/skid plate | E8TZ-9A147-B | L.H. - use w/aft axle fuel tank | 1
F350--4/W/D - 133" W/B - 7.3L diesel w/E4OD "FROM 2/94" | F4TZ-9A147-A | Use w/auxiliary fuel tank | 1
F350--4/W/D w/117", 133", 139", 155", 168" W/B w/skid plates-7.3L diesel (all) or gas "FROM 2/94" | F5TZ-9A147-A | R.H.-Use w/aft axle fuel tank (Mandatory w/DI Turbo engine) | 1
F350, F(Super Duty)--Diesel DI Turbo-w/137", 161", 185" W/B | F5TZ-9A147-G | Aft axle | 1
F350--4x4 "BEFORE 7/15/96" | F6TZ-9A147-KA | Midship/Auxiliary; 42" long | 1
F350--4x4 | F6TZ-9A147-GA | Midship/Auxiliary fuel tank; 60 1/2" long. | 1
F250--4x4, O/8500 GVW | F6TZ-9A147-KA | Midship/Auxiliary; 42" long | 1
F250--4x4, O/8500 GVW "BEFORE 7/15/96" | F6TZ-9A147-KA | Midship/Auxiliary; 42" long | 1
F350 | 382802-S2 | (MM-173-JB) - nut - hex. flange - 3/8" - 16 | AR
F350 | 377689-S2 | (MM-269-E) - nut - spring - 3/8" - 16 | AR
F350 | 56341-S2 | Bolt (skid plate to frame cross member) - hex. head - 3/8" - 16 x 1 1/4" - use w/aft axle fuel tank | 7
9155 FILTER ASY. (FUEL)
F350, F(Super Duty)--Diesel-DI Turbo, exc. Calif. Ems. | F6TZ-9155-AB | Fuel/Water/Filter Separator Assy. Service all details in assembly except Filter F4TZ-9N184-A | 1
F350--Diesel-DI Turbo, w/Calif. Ems. | F6TZ-9155-B | Fuel/Water/Filter Separator Assy. Service all details in assembly except Filter F4TZ-9N184-A | 1
F250--Diesel-DI Turbo, exc. Calif. Ems.; O/8500 GVW | F6TZ-9155-AB | Fuel/Water/Filter Separator Assy. Service all details in assembly except Filter F4TZ-9N184-A | 1
F250--Diesel-DI Turbo, w/Calif. Ems.;O/8500 GVW | F6TZ-9155-B | Fuel/Water/Filter Separator Assy. Service all details in assembly except Filter F4TZ-9N184-A | 1
9160 GASKET (FUEL FILTER SEDIMENT BOWL)
F350, F(Super Duty)--7.3L Diesel | F6TZ-9160-AA | Copper, 3/4" O.D. x 9/16" I.D. x 1/16" thick. | 1
F250--7.3L Diesel, O/8500 GVW | F6TZ-9160-AA | Copper, 3/4" O.D. x 9/16" I.D. x 1/16" thick. | 1
9N163 ACCUMULATOR ASY (FUEL)
F350, F(Super Duty), F59(Stripped Chassis)--7.3L Calif. Ems. | F6TZ-9N163-AA | 1
F250--7.3L Calif. Ems., O/8500 GVW | F6TZ-9N163-AA | 1
9N184 ELEMENT ASY. (FUEL/WATER SEPARATOR)
F350, F(Super Duty)--Diesel-DI Turbo | F4TZ-9N184-A *FD-4595 | Includes element, bevel-cut gasket, service instructions. Also serviced in F4TZ-9155-AB filter assy-fuel/water separtor | 1
9189 VALVE ASY. (FUEL TANK SELECTOR)
F350, F(Super Duty)--diesel-dual tanks "FROM 2/94" | F4TZ-9189-A | contains (6) ports | 1
9229 O RING (INJECTOR)
F350, F(Super Duty)--7.3L DI Turbo | XC3Z-9229-AB | Kit--contains 8 different o rings/seals to service one 9E527 fuel injector. | 1
F250--7.3L DI Turbo, O/8500 GVW | XC3Z-9229-AB | Kit--contains 8 different o rings/seals to service one 9E527 fuel injector. | 1
9232 NUT (FUEL HEATER TUBE)
F350, F(Super Duty)--7.3L DI Turbo Diesel | F4TZ-9232-A | Bolt-M10 x 20 hex flange. Used to mount F4TZ-14A163-D clamp. | 1
F350, F(Super Duty)--DI Turbo diesel | F4TZ-9232-C | Bolt-M8 x 16 hex flange. One req'd w/9D319 clamp attach 9A318/9C330 fuel tubes & one req'd w/9W310 clip to attach 9L273 drain tube | 2
F350, F(Super Duty)--DI Turbo diesel | F5TZ-9232-A | Nut-M5 Hex Prevailing Torque. Use w/F5TZ-9N653-A clamp to secure high pressure supply hoses 9A332/9J323. | 2
F59(Stripped Chassis--DI Turbo diesel | F4TZ-9232-C | Bolt-M8 x 16 hex flange. One req'd w/9D319 clamp attach 9A318/9C330 fuel tubes & one req'd w/9W310 clip to attach 9L273 drain tube | 2
9240 FUEL TANK (SHIELD - HEAT)
F350--133" W/B - diesel | FOTZ-9240-E | Side shield | 1
F350, F(Super Duty) | E7TZ-9240-D | Front of rear tank | 3
F350, F(Super Duty) | E8TZ-9240-A | Front tank top of tank between gussets | 2
F350, F(Super Duty)--4/W/D w/117", 133", 139", 155", 168" W/B w/skid plate | FOTZ-9240-D | Rear tank under support straps | 2
F350, F(Super Duty)--137", 161", 185" W/B | F5TZ-9240-B | Side shield for aux. fuel tank | 1
9B249 HEADER (FUEL FILTER)
F350, F(Super Duty), F59(Stripped Chassis)--Diesel-exc DI Turbo | F2TZ-9B249-A | 1
9B253 ELBOW (FUEL FILTER TUBE)
F250, F350, F(Super Duty)--O/8500 GVW, 7.3L D.I. Turbo "FROM 4/15/96" | 9B253 | Use "9C402" 90 deg. fitting
9B254 FITTING (TUBE ADAPTER FUEL FILTER)
F350. F(Super Duty)--Diesel-DI Turbo | F4TZ-9B254-B | Connector-1/4 o.d. tube 37 deg flare x 1/8 npt...Fuel return tube 9D308 connect to L.H. cyl Head | 1
F350. F(Super Duty)--Diesel-DI Turbo | F4TZ-9B254-A | Connector-straight flex 1/4 o.d. tube x 1/8 npt (no seal)..Fuel supply tube 9A564 connect to R.H. cyl head | 1
F59(Stripped Chassis)--Diesel-DI Turbo | F4TZ-9B254-B | Connector-1/4 o.d. tube 37 deg flare x 1/8 npt...Fuel return tube 9D308 connect to L.H. cyl Head | 1
9K260 SLEEVE (FUEL LINE CONNECTOR)
F350, F(Super Duty), F59(Stripped Chassis)--Diesel(exc DI Turbo)-M/T | E3TZ-9K260-A | 2
9B268 SEAL (FUEL FILTER DRAIN PLUG)
F350, F(Super Duty), F59(Stripped Chassis)--Diesel-exc DI Turbo | E8TZ-9B268-A | 1
9B273 TUBE ASY. (FUEL PUMP TO FUEL FILTER)
F350, F(Super Duty)--Diesel-DI Turbo | F4TZ-9B273-A | Hose assy-fuel return-R.H. cyl head to fuel filter | 1
9L273 TUBE (FUEL FILTER OUTLET)
F350, F(Super Duty)--Diesel-DI Turbo | F4TZ-9L273-A | attach to fuel filter water drain hose (9324) | 1
9S273 TUBE ASY. (SUPPLY FUEL LINE TO FUEL RAIL)
F350, F(Super Duty)--7.3L DI Turbo | F5TZ-9S273-H | 1
9S274 TUBE ASY. (FUEL LINE TO FUEL RAIL RETURN)
F350, F(Super Duty)--7.3L DI Turbo | F5TZ-9S274-H | 1
9275 GAUGE ASY. (SENDER ASY. - FUEL TANK UNIT - DIESEL)
F59(Stripped Chassis) | E9TZ-9275-A | 1
F350, F(Super Duty)--152" W/B | F5TZ-9275-F | 17 gal.-Midship (Steel) | 1
F350, F(Super Duty)--18 gal. Steel aft axle tank | F6TZ-9275-DA | Stainless steel tube/flange. | 1
F350, F(Super Duty)--19 gal. Plastic aft axle tank | F6TZ-9275-AA | Stainless steel tube/flange. | 1
F350, F(Super Duty)--19 gal. Steel midship tank | F6TZ-9275-CA | Stainless steel tube/flange, excludes fuel tank port extension tube. | 1
F350, F(Super Duty)--19 gal. midship tank, O/8500 GVW | F6TZ-9275-EA | Stainless steel tube/flange, includes extension fuel tube port. | 1
F350, F(Super Duty)--23 gal. Plastic midship tank | F6TZ-9275-BA | Stainless steel tube/flange. | 1
F250--18 gal. Steel aft axle tank; O/8500 GVW | F6TZ-9275-DA | Stainless steel tube/flange. | 1
F250--19 gal. Steel midship tank, O/8500 GVW | F6TZ-9275-CA | Stainless steel tube/flange, w/o fuel tank port extension tube. | 1
F250--19 gal. midship tank, O/8500 GVW | F6TZ-9375-EA | Stainless steel tube/flange, w/extension fuel tube port. | 1
F250--23 gal. Plastic midship tank; O/8500 GVW | F6TZ-9275-BA | Stainless steel tube/flange. | 1
F250--O/8500 GVW; 19 gal. Plastic aft axle tank | F6TZ-9275-AA | Stainless steel tube/flange. | 1
9F276 CLIP (FUEL AND BRAKE LINE)
F350--all | F2TZ-9F276-A | AR
9S277 HARNESS ASY. (FUEL FILTER/WATER SEPARATOR)
F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9S277-AA | Also serviced in 9155. Note: Lt. blue rectangular ribbed seal to fuel heater connector is 1807278-C1. | 1
9278 SENDER ASY. (OIL PRESSURE ENGINE UNIT)
F350, F(Super Duty), F59(Stripped Chassis)--7.3L DI Turbo | F6TZ-9278-AA *SW-5155 | Oil Pressure Gauge (1825252C1). includes O-ring (F4TZ-9C064-A) | 1
9B278 HOSE ASY. (OIL PRESSURE INDICATOR)
F350, S(Super Duty), F59(Stripped Chassis)--Diesel | E3TZ-9B278-A | 1
9D278 SOLENOID ASY. (FUEL SHUT OFF VAVLE)
F350--Diesel | 9D278 | Also refer to group 9K523 if not listed available only in 9A543 | 1
9J278 RETAINER (FUEL TUBE)
F350, F(Super Duty) | F5TZ-9J278-A | C shaped - fuel quick connect dual clips. Return of supply lines. | 1
9280 GAUGE ASY. (FUEL INSTRUMENT PANEL UNIT)
F350, F(Super Duty)--diesel, USA/Canada | F5TZ-9280-DA | Fuel & amp, diesel only; white ISO battery & fuel symbols, component of cluster designs from F6TF-10849-*E. | 1
F250--diesel, USA/Canada; O/8500 GVW | F5TZ-9280-DA | Fuel & amp, diesel only; white ISO battery & fuel symbols, component of cluster designs from F6TF-10849-*E. | 1
9S281 CONTROL ASY. (FUEL/WATER SEPARATOR)
F350, F(Super Duty)--7.3L DI Turbo | F4TZ-9S281-A | Water sensor switch | 1
9C291 SHIELD (FUEL HOSE)
F350, F(Super Duty)--7.3L | E4TZ-9C291-B | Used to prevent water separator hoses from kinking | 1
F350, F(Super Duty)--7.3L, 7.5L | E4TZ-9C291-A | Use with dual tanks - not used w/nylon fuel line | 1
F350, F(Super Duty)--Diesel-DI Turbo | F4TZ-9C291-A | Shield-heat fuel transfer pump/fuel lines | 1
9D308 TUBE ASY. (FUEL RETURN)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9D308-A | Hose w/fittings. D/L= 13 1/2". Fuel return L.H. Cyl Hd to Fuel Filter | 1
9W310 CLIP (WATER DRAIN TUBE - FUEL FILTER)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9W310-A | Clip-Water Drain Tube 9L273 from fuel/water separator | 1
9E313 GUARD (FUEL HOSE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-F | 12 1/2" long convoluted tube. High pressure manifold return hose to L.H. cyl head | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-D | 3 1/2" long convoluted tube. High pressure manifold supply hose R.H. side rear | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-B | 4 1/2" long convoluted tube. High pressure manifold supply hose L.H. side front | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-A | 5 3/4" long convoluted tube. High pressure manifold supply hose L.H. side-Rear | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-C | 7 1/2" long convoluted tube. High pressure manifold supplu hose R.H. side front | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E313-E | 9" long convoluted tube. High pressure manifold return hose to R.H. cyl head | 1
9A318 TUBE ASY. (FUEL FRONT)
F250, F350, F(Super Duty)--7.3L DI Turbo | F5TZ-9A318-C | Tube-fuel/water separator filter assy to chassis. Use only w/F5TZ-9C330-C. | 1
9D319 BRACKET (FUEL TUBE SUPPORT)
F250, F350, F(Super Duty)--7.3L DI Turbo | 8 Cyl. 7.3 | F4TZ-9D319-A | Clamp-upper fuel supply & return tubes 9A318/9C330. Use w/bolt F4TZ-9232-C M8 x 16 hx flng | 1
9K319 CONNECTOR (FUEL VAPOR HOSE RESTRICTING)
F(Super Duty) | 8 Cyl. 7.3 | EOVY-9K319-A | #Black-orifice-0.170" (nylon) | 1
9N320 ELBOW (FUEL TANK INLET TUBE)
F250, F350, F(Super Duty)--7.3L DI Turbo | F4TZ-9N320-A | Attach 9B273 fuel return tube to r.h. cyl head-front. Also serviced in 9155 fuel/water separator (connects 9D308 & 9B273 tubes.) | 3
9B322 TUBE ASY. (FUEL TANK TO SELECT VALVE INTERMEDIATE)
F250, F350, F(Super Duty)--w/185" W/B--Turbo(IDI/DI) | 8 Cyl. 7.3 | F5TZ-9B322-A | 1
9J323 TUBE ASY. (FUEL PUMP TO FUEL RAIL)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9J323-A | Hose Assy.-Fuel high pressure manifold supply R.H. side. | 1
9324 HOSE (FUEL TUBE CONNECTOR)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9324-AA *KFL-32 | Fuel/water separator drain hose to tube 9L273 | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9324-BA *KFL-33 | Heat Resistant (minus 40F-300F). 5/16" I.D. x 1.5" D/L. Fuel return tube 9A318 to fuel/water separator 9155. | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9324-DA *KFL-35 | Heat resistant (3/8" I.D. x 2.0" D/L). Fuel supply (9C330) to fuel transfer pump (9350). Fuel/water separtator (9155) return to fuel transfer pump (9350). | 2
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9324-CA *KFL-34 | Heat resistant (minus 40F-300F). 3/8" I.D. x 2.88" D/L. Fuel transfer pump (9350) supply to fuel/water separator (9155) | 1
E350, E(Super DUty), F250, F350, F(Super Duty) | 8 Cyl. 7.3 | 353473-S8 | (GG-213-T) Clip | 1
9327 HOSE (FUEL TUBE LOWER)
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9327-CA | Use w/Aft Axle Fuel Tank (Plastic). Also serviced in 9034. D/L= 1388mm | 1
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9327-BA | Use w/Aft Axle Fuel Tank (Steel). Also serviced in 9034. D/L= 1310mm | 1
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9327-AA | Use w/Midship Fuel Tank. Also serviced in 9034. D/L= 1230mm | 1
9C330 TUBE ASY. (FUEL PUMP TO FUEL FILTER)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F5TZ-9C330-C | Tube Assy w/mtg clip-Fuel Supply...Transfer pump to chassis supply line. Use only w/F5TZ-9A318-C. | 1
9A332 HOSE ASY. (FUEL HIGH PRESSURE MANIFOLD SUPPLY)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9A332-A | Hose Assy.- Fuel high pressure manifold supply L.H. side | 1
9N332 ELBOW ASY. (HIGH PRESSURE HOSE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9N332-A | Elbow assy-90 deg boss w/O ring F4TZ-9N693-A. Connects high pressure hoses 9J323/9A332 to cyl heads | 2
9C334 CLAMP (FUEL RETURN HOSE AT PUMP)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9C334-AA | 10
9H334 TUBE ASY. (FUEL SUPPLY AND RETURN FRONT)
F(Super Duty)--185" W/B DI Turbo | F5TZ-9H334-A | 1
F250, F350--133", 155", 168" W/B DI Turbo | F5TZ-9H334-D | 1
F250, F350, F(Super Duty)--137" W/B DI Turbo | F5TZ-9H334-B | 1
F250, F350, F(Super Duty)--161" W/B DI Turbo | F5TZ-9H334-C | 1
F250--Crew Cab--152" W/B | F5TZ-9H334-E | Connects to Midship fuel tank | 1
F250, F350--w/139" W/B | F5TZ-9H334-E | 1
9J337 TUBE ASY. (FUEL SUPPLY AND RETURN)
F(Super Duty)--185" W/B DI Turbo | 8 Cyl. 7.3 | F5TZ-9J337-A | 1
F250, F350--133", 155", 168" W/B DI-Turbo | 8 Cyl. 7.3 | F5TZ-9J337-D | 1
F250, F350, F(Super Duty)--137" W/B-DI Turbo | 8 Cyl. 7.3 | F5TZ-9J337-B | 1
F250, F350--139" W/B | F5TZ-9J337-E | 8 Cyl. 7.3 | Connects to Aft Axle fuel tank | 1
F250, F350, F(Super Duty)--161" W/B-DI Turbo | 8 Cyl. 7.3 | F5TZ-9J337-C | 1
F250--Crew Cab--152" W/B | F5TZ-9J337-E | 8 Cyl. 7.3 | Connects to Aft Axle fuel tank | 1
9J338 TUBE ASY. (FUEL ENGINE SUPPLY AND RETURN)
F350--168" W/B--DI Turbo | 8 Cyl. 7.3 | F5TZ-9J338-A | 1
F250, F350, F(Super Duty)--133", 137", 161", 185", W/B--DI Turbo | 8 Cyl. 7.3 | F5TZ-9J338-C | Use w/Dual fuel tanks | 1
F250, F350--155" W/B--DI Turbo | 8 Cyl. 7.3 | F5TZ-9J338-D | 1
9350 PUMP ASY. (FUEL ENGINE MOUNTED - DIESEL)
F250, F350, F(Super Duty)--7.3L DI Turbo | F6TZ-9350-A | Transfer pump. Attaches to fuel/water/filter separator (9155). Attaching bolts-9R534. | 1
9A375 GASKET (FUEL TRANSFER PUMP FITTING SUPPLY PIPE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9A375-A | Gasket-fuel transfer pump fitting supply pipe 9A564 | 2
9C387 O RING (FUEL TUBE RETURN LINE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9C387-A | Sleeve 1/4" O.D. tube. Also servived (1-each end) in 9A564 fuel supply tube assy. | 2
9C402 ELBOW (FUEL PUMP HEATER TUBE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9C402-AA | Elbow-90 deg. Fuel supply 9A564 at L.H. cyl head. | 1
9417 GASKET (FUEL PUMP MOUNTING)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9417-AA | Gasket-high pressure oil injection pump | 1
9G425 BRACKET (MAP SENSOR)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | E7TZ-9G425-A | Attaches 9F479 Map Sensor | 1
9S425 BOLT (EXHAUST MANIFOLD)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9S425-A | Flange bolt. Attach R.H. (7) & L.H. (8) exhaust manifold to block. | 16
9430 MANIFOLD (EXHAUST)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9430-B | R.H. | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9431-B | L.H. | 1
9J432 BRACKET (TRANSDUCER MOUNTING)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9J432-B | Bracket assy-Exhaust Back Pressure (EBP) & engine cover front | 1
9E434 COVER (INTAKE MANIFOLD)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9E434-BA | L.H. - Air Intake. Uses (9) bolts 1824393-c1 & (1) stud bolt 1821889-c1. | 1
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9E434-AA | R.H. - Air Intake. Uses (8) bolts 1824393-c1 * (2) stud bolts 1820516-c1. | 1
9E436 GASKET (FUEL RAIL TO PLENUM)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E436-A | Seal-Turbo compressor outlet (mounts between 6K682 & 6K889) | 1
9448 GASKET (EXHAUST MANIFOLD)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9448-A | 2
9A451 WIRE ASY. (GLOW PLUG)
F(Super Duty)--DI Turbo | F7TZ-9A451-CA | 8 Cyl. 7.3 | Harness asy.-w/glow plug relay 12B533 & cover 12A345. | 1
F250, F350--DI Turbo--exc. Calif. Ems. | 8 Cyl. 7.3 | F7TZ-9A451-CA | Harness asy.-w/glow plug relay 12B533 & cover 12A345. | 1
F250, F350--DI Turbo--Calif. Ems. | 8 Cyl. 7.3 | F7TZ-9A451-BA | Harness asy.-w/glow plug relay 12B533 & cover 12A345. | 1
9J460 SENSOR ASY. (EGR PRESSURE VALVE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F7TZ-9J460-AA | Transducer-exhaust back pressure. Includes seal 1807264-C1. Mounts to 9J432. | 1
9L474 HOSE (MANIFOLD ABSOLUTE PRESSURE SENSOR)
F250, F350, F(Super Duty)--DI Turbo 8 Cyl. 7.3 || F5TZ-9L474-B | 1
9D477 TUBE (EXHAUST GAS RECIRCULATING VALVE TO EXHAUST MANIFOLD
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9D477-A | Tube-Exhaust Back Pressure Sensor. Uses 9F485 1/4" -18 connector. | 1
9F479 SENSOR (MANIFOLD ABSOLUTE PRESSURE)
F250, F350, F(Super Duty)--DI Turbo | F4TZ-9F479-A *DY708 | #F4TF-9S480-AA (Sensor). Attaching bracket= 9G425. | 1
9F485 CONNECTOR (EGR EXHAUST MANIFOLD)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9F485-B | Connector-5/16 tube flared. Connects to 9D477 tube exhaust back pressure sensor. | 1
9G486 TURBINE HOUSING BOLT (TURBO TO PEDESTAL)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F5TZ-9G486-AA | Consists of (8) turbo to pedestal bolts. (11) turbo housing attachment bolts. | 1
9C490 MANIFOLD ASY. (VACUUM OUTLET)
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F6TZ-9C490-A | 4 ports. Mounts to fender apron. | 1
9N517 BOLT (INJECTOR PUMP GEAR)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9N517-A | Bolt-M10 x 35 mounts 9155 fuel/water separator | 2
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9N571-B | Bolt-M8 x 50 mm hex flange..(5) reqd to mount 6881 to engine both ends. (1) reqd to mount high pressure oil inj pump (9A543). (4) reqd to mount 6K682 turbo | 10
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9N517-C | Bolt-M8 x 70mm hex flange..Attach high pressure oil inj pump (9A543) | 1
9R523 BOLT (FUEL INJECTOR HOLD DOWN)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9R523-A | Bolt-shoulder. 39mm long w/25mm thread length. Fuel injector (9E527) hold down bolt. One reqd per injector. Also serviced w/9E527. | 8
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9R523-C | Bolt-shoulder. 48mm long w 24mm thread length. Fuel injector (9E527) hold down bolt. One reqd per injector. Also serviced w/9E527. | 8
9S523 ROD ASY. (MULTIPORT FUEL INJECTION SECONDARY THROTTLE)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9S523-A | Tappet-Fuel transfer pump (9350). Also serviced in 9350. | 1
9G524 SPOUT (OIL DEFLECTOR - FUEL INJECTOR)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9G524-A | Fuel injector oil director..Mounts to each fuel injector hold down clamp. | 8
9E527 NOZZLE AND HOLDER ASY. (FUEL INJECTOR)
F(Super Duty)--DI Turbo--All | 8 Cyl. 7.3 | F4TZ-9E527-A | Injector assy-fuel..Remanufactured (1822801-C92). Seals/O-rings/Gaskets also serviced in 9229 kit. Includes 9R523 mtg bolts. | 8
F250, F350--DI Turbo--Calif. Ems. | 8 Cyl. 7.3 | F6TZ=9E527-A | Injector Assy.-fuel. Remanufactured (1824583-C91). Assembled w/seals, o-rings, gaskets which are also serviced in 9229 kit. Includes 9%523 mtg. bolts. | 8
F250, F350--DI Turbo--exc. Calif. Ems. | 8 Cyl. 7.3 | F4TZ-9E527-A | Injector assy-fuel..Remanufactured (1822801-C92). Seals/O-rings/Gaskets also serviced in 9229 kit. Includes 9R523 mtg bolts. | 8
BOLT (FUEL TRANSFER PUMP)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9R534-A | Bolt-M8 x 30 hex flange. Reqd (2) attach 9350 fuel transfer pump. Reqd (4) to attach 6N632 flange to 6K854 tubes. (5) reqd attach 8501 water pump. | 11
9F538 SLEEVE (FUEL INJECTOR)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9F538-A | Sleeve-fuel injector..Mounts into cyl head--One per fuel injector. | 8
9A543 PUMP ASY. (FUEL INJECTION)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F6TZ-9A543-AA | Pump Asy.-High Pressure Oil (Hyd Oil Injection Pump). Pump #1825259-C91. Pump ID 259-C91. Attaching gear is 6655. Use w/ICP Regulator F5TZ-9C968-A (#1825250-C91) which has open end orifice stem. | 1
9R549 BOLT (FUEL OUTLET SUPPLY PIPE TO TRANSFER FUEL PUMP)
F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9R549-A | Bolt-1.75" long. Attach fuel outlet supply pipe to fuel transfer pump. | 1
F250, F350--DI Turbo--Calif. Ems. | 8 Cyl. 7.3 | F6TZ-9R549-AA | Bolt-banjo connector. Attach fuel accumulator 9N163 to 9A564 & 9A564 fuel supply tube to fuel transfer pump 9350. | 1
F250, F350--DI Turbo--exc. Calif. Ems. | 8 Cyl. 7.3 | F4TZ-9R549-A | Bolt-1.75" long. Attach fuel outlet supply pipe to fuel transfer pump. | 1
9R551 BOLT (FUEL INJECTOR OIL DIRECTOR SPOUT)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9R551-A | Bolt-M6 x 35mm hex shoulder head. Mounts fuel injector oil director spout 9G524. | 8
9A564 TEE (FUEL RETURN)
F(Super Duty)--DI Turbo "FROM 7/15/96" | 8 Cyl. 7.3 | F6TZ-9A564-CA | Tube Asy.-fuel supply (Wishbone shape) to cyl heads from fuel transfer pump (9350). Use with one (1) 90 deg elbow 9C402 to attach to L.H. cyl hd. | 1
F250, F350--DI Turbo - Calif. Ems. | 8 Cyl. 7.3 | F6TZ-9A564-BA | Tube Asy.-fuel supply (Wishbone shape) to cyl heads from fuel transfer pump (9350). Use with one (1) 90 deg elbow 9C402 to attach to L.H. cyl head. Note: 9N163 Accumulator & 9160 gskt fits on top use with 9R549 banjo bolt. | 1
F250, F350--DI Turbo - exc. Calif. Ems. | 8 Cyl. 7.3 | F6TZ-9A564-CA | Tube Asy.-fuel supply (Wishbone shape) to cyl heads from fuel transfer pump (9350). Use with one (1) 90 deg elbow 9C402 to attach to L.H. cyl hd. | 1
9E583 SEAL (FUEL TRANSFER PUMP)
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F4TZ-9E583-B | Seal-fuel transfer pump (9350). .609 I.D. Also serv in 9350. | 1
9B593 VALVE ASY. (FUEL VAPOR)
F250, F350, F(Super Duty)--Chassis Cab--Aft Axle | 8 Cyl. 7.3 | F4TZ-9B593-H | 1 port. 31mm length into fuel tank | 1
F250, F350, F(Super Duty)--Chassis Cab--Midship | 8 Cyl. 7.3 | F4TZ-9B593-G | 1 port. 75mm length into fuel tank | 1
F250, F350, F(Super Duty)--exc. Chassis Cab | 8 Cyl. 7.3 | E7DZ-9B593-A | 1 port | 2
9F597 VALVE ASY. (FUEL PUMP RELIEF)
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F2TZ-9F597-A | Fuel priming. | 1
9N622 INDICATOR ASY. AIR CLEANER RESTRICTOR
F250, F350, F(Super Duty)--DI Turbo | 8 Cyl. 7.3 | F5TZ-9N622-A | 1
9N653 CLAMP ASY. (FUEL INJECTION PUMP TUBE)
F350, F(Super Duty), F59(Stripped Chassis) | 8 Cyl. 7.3 | F4TZ-9N653-A r/b F5TZ-9N653-A | D.I. Turbo Diesel 1821857c1 | 1
F350, F(Super Duty), F59(Stripped Chassis) | 8 Cyl. 7.3 | F5TZ-9N653-A | D.I. Turbo Diesel 1821857c1 | 1
9N659 CLIP (FUEL INJECTION PUMP TUBE)
F350, F(Super Duty), F59(Stripped Chassis)--D.I. Turbo | 8 Cyl. 7.3 | F4TZ-9N659-B | 1
F59(Stripped Chassis) | 8 Cyl. 7.3 | F4TZ-9N659-A | D.I. Turbo Diesel 1807269c1 | 1
9C675 TUBE ASY. (AIR CLEANER AIR INTAKE)
F350 | 7.3 | F5TZ-9C675-A | DI Turbo Eng. | 1
9B676 ADAPTER (AIR CLEANER AIR DUCT TUBE)
F250, F350, F(Super Duty), F59(Stripped Chassis) | 8 Cyl. 7.3 | F5TZ-9B676-A | 1
NUT (AIR CLEANER CLAMP)
F250, F350, F(Super Duty), F59(Stripped Chassis)--all D.I. Turbo Eng. | 8 Cyl. 7.3 | F6TZ-9B680-AA | 2
9C681 HOSE (AIR CLEANER TO TURBO)
F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9C681-B r/b F7TZ-9C681-AA | D.I. Turbo | 1
9N693 RING/SEAL (INJETION PUMP TO FITTING - SEALING)
F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9N693-A | D.I. Turbo Diesel 1815874c1 | 1
9793 BOOT/PLUG
F350, F(Super Duty)--Plugs rod hole on elec. pedal | 8 Cyl. 7.3 | F5TZ-9793-A |
9N809 REINFORCEMENT (ACCELERATOR PEDAL)
F350 | F5TZ-9N809-A | D.I. Turbo | 1
9F832 SENSOR ASY. ACCELERATOR
F350 | 8 Cyl. 7.3 | F5TZ-9F832-B r/b F5TZ-9F836-A | D.I. Turbo | 1
9F836 PEDAL & SENSOR ASY. (ACCELERATOR)
F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9F836-A r/b F5TZ-9F836-A | 8/94 | 1
F(Super Duty) | 8 Cyl. 7.3 | F6TZ-9F836-AA | 1
9F838 SENSOR ASY. (FUEL INEJTOR TIMING)
F350, F(Super Duty), F59(Stripped Chassis) | 8 Cyl. 7.3 | F4TZ-9F838-A | D.I. Turbo 1812818c2 | 1
9C899 BRUSH ASY. (SPEED CONTROL ELECTRICAL GROUND CONTACT)
F250, F350, F(Super Duty)--W/O AIR BAG | ALL | F6TZ-9C899-AA | 1
9F924 SWITCH ASY. (SPEED CONTROL - DEACTIVATOR)
F350 | ALL | F3TZ-9F924-B | 1
9D930 WIRE ASY. (FUEL CHARGE)
F350, F(Super Duty), F59(Stripped Chassis)--D.I. | 8 Cyl. 7.3 | F4TZ-9D930-H | #1815923-C91 | 2
F250, F350, F(Super Duty) | 8 Cyl. 7.3 | F4TZ-9D930-K | #1815923 C9 | 1
9C977 GASKET (FUEL PRESSURE REGULATOR)
F250, F350, F(Super Duty)--IPR Seal Kit | 8 Cyl. 7.3) | F6TZ-9C977-AN | 1825806 c91 | 1
Holiday Cheers from Orlando, FL! :)
Dave
Do you rattle off partnumbers and TSB's in your sleep. I don't see how you do it. Thanks a lot. /ubbthreads/images/graemlins/smile.gif
ROTFLMAO!! /ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/biggrin.gif
I'm not that obsessed (yet). I just have all this Power Stroke-related material and look for ways to make it available to others. /ubbthreads/images/graemlins/cool.gif If I've been looking for something, I know at least ten others here on TheDieselStop are as well. /ubbthreads/images/graemlins/smile.gif
I'm also working a Big Ford Engine Part Numbers Post so expect that in the future. /ubbthreads/images/graemlins/cool.gif
Holiday Cheers from Orlando, FL! /ubbthreads/images/graemlins/smile.gif
Dave
