The Effects of Biodiesel Properties on Diesel Injection Timing, M. Tat* 1 ,J. Van Gerpen 1 ,1 Iowa State University, United States.
Biodiesel is defined as an alternative diesel fuel comprised of mono alkyl esters of long chain fatty acids derived from vegetable oils or animal fats. Biodiesel is completely soluble in petroleum-based diesel fuel, so biodiesel can be used as a blend with petroleum-based diesel fuel. However, biodiesel has different physical properties that affect the diesel fuel injection system and the diesel engine emissions. Biodiesel has a higher speed of sound, isentropic bulk modulus, density, and viscosity that change the fuel injection timing and engine emissions. The objective in this study was to investigate the effect of biodiesel's speed of sound, isentropic bulk modulus, density, and viscosity on diesel injection timing. A John Deere 4045 T diesel engine was used for this research and three different distributor type fuel injection pumps were tested.It was found that the properties of biodiesel affects the fuel injection system and advances the fuel injection timing. These changes were found to be dependent on the specific fuel injection pump used and this was attributed to variations in factory tolerances. It was observed that the start of injection timing of biodiesel was advanced about 0.68 to 1.38 crank angle compared with petroleum-based diesel fuel. When comparing the different fuel injection pumps it was found that from half to all of the advancement was due to the increase in the fuel delivery needed to overcome the power loss that results from biodiesel's lower energy content. As much as half of the advancement was due to the higher speed of sound and isentropic bulk modulus of biodiesel fuel. It was also found that at the same temperature, the fuel delivery of biodiesel was higher than for petroleum-based diesel fuel because of the higher viscosity of biodiesel. At the same viscosity level, it was found that the fuel delivery of petroleum-based diesel fuel was still higher than biodiesel. This was judged to be a result of the orifices in the fuel injection pumps restricting the amount of fuel flow for more dense fuels and the reduction in the amount of fuel delivery affects the fuel injection timing.It was concluded that the different fuel properties of biodiesel have a significant effect on the injection timing. Increasing fuel delivery advances the fuel injection timing following the design characteristics of the pump. The higher speed of sound and the isentropic bulk modulus of biodiesel also advance the fuel injection timing. Additional timing effects were identified as resulting from density and viscosity changes. However, these effects vary for each fuel injection system and in some cases may cancel. It was also concluded that the effects of some properties are coupled and cannot be separately identified by changing one without changing the other, such as density and viscosity.
If bioD is so good for an engine, how good is it to change the injection timing? /ubbthreads/images/graemlins/shrug.gif I've noticed a big difference between running #2 and then B99 or WVO. My acceleration and max boost readings are always slower and lower on bio fuels. /ubbthreads/images/graemlins/confused.gif
