I have a 99.5 7.3 I just replaced every hose on the hydro boost system I need to bleed the thing. Many different ways and variations of bleeding the system as per my research. Front end on jack stand turn wheel all the way right, all the way left 5 times, then pump brakes 3 times that’s a cycle they say do this 40 times checking fluid as you go topping off. I do this my p/s reservoir lid pops off and vomits fluid. What am I missing here
The engine has to be running when you do it. It does not take that many turns of the steering wheel to do it. 5-10, pump the brakes a few times and see what you get.
DENNY
I found turning the wheel slowly is helpful as well as what Denny said above.
