Stumbled across this, to greatly speed up the purging of air from the fuel system when changing the injectors and or pump, disconnect the power lead to the cold start valve on the injection pump (yellow wire at the rear of pump). This allows the air to escape much faster from the now unrestricted return line fitting. About 4, four or five second cranks on the starter with the throttle held to the floor (all of the injector lines about 1/2 turn loose at the injectors) and you will see fuel at the injector line nuts, tighten the line nuts and your ready to make smoke.
