· Banned
Blending Mineral Spirits with Vegetable Oil to Make VO Blend Diesel Fuel
Making vegetable oil blend Diesel Fuel (VOBDF) by blending Mineral Spirits with vegetable oil
Mineral Spirits [CAS 64475-85-0][1][2], also called Stoddard solvent [CAS 8052-41-3][3] or white spirits[4], is a petroleum distillate commonly used as a paint thinner and mild solvent. Outside of the United States and Canada, it is referred to as white spirit. In industry, mineral spirits is used for cleaning and degreasing machine tools and parts. According to Wesco, a supplier of solvents and cleaning equipment, mineral spirits "are especially effective in removing oils, greases, carbon, and other material from metal." Mineral spirits may also be used in conjunction with cutting oil as a thread cutting and reaming lubricant.
Artists use mineral spirits as an alternative to turpentine, one that is both less flammable and less toxic. Because of interactions with pigments, artists require a higher grade of mineral spirits than many industrial users, including the complete absence of residual sulfur. Odorless Mineral Spirits are mineral spirits that have been further refined to remove the more toxic aromatic compounds, and are recommended for applications such as oil painting, where humans have close contact with the solvent.
In screen printing (also referred to as silk-screening), mineral spirits are often used to clean and unclog screens after printing with oil-based textile and plastisol inks. They are also used to thin inks used in making monoprints.
Mineral spirits are often used inside liquid filled compasses and gauges.
A typical composition for mineral spirits is the following: > 65% C10 or higher hydrocarbons[5], aliphatic solvent hexane, and a maximum aromatic hydrocarbon content of 0.1% by volume, a kauri-butanol value of 29, an initial boiling point of 149 °F (65 °C), a dry point of approximately 156 °F (69 °C), and a specific mass of 0.7 g/cc.
