I have a 2008 f250 with 6.4 . The wipers and blower quit and from what I understand there is a common issue with a wire rubbing threw along core suppor under fan shroud I was wondering if anyone had any info on specific locations from past experiences . And yes fuses and relays are all good I just don't have power to my relay on pin 86 like there should be
Discussion Starter · #2 ·
Ok I got it repaired if anyone comes across this thread with the same issue . It is a yellow wire in harness that goes under passenger battery tray and runs along bottom fan shroud the wire was broken directly above the frame very hard to reach . There is a big plastic harness holder the break was a few inches past that there is also 2 solid yellow wires in that harness so becareful the one you want goes to fuse 45 in passenger kick panel .. If further help is needed email me at [email protected]
