What year was the 8 lug pattern changed from 8x6.5 to 8x170mm. I found a used set of rims for my Dodge. I have axles off a 97 3/4 ton n the rims are off a 99 F-250 PSD. I want to know if they will bolt up. Thanks
· Administrator
You're out of luck on those 99 wheels. The 97's had the 6.5in bolt circle and the 99's had 170mm. You'll need wheels from an OBS truck.
